coralman's front axle rebuild - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > coralman's front axle rebuild
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 05-11-2013, 02:48 PM   #46
coralman
its the beam Jim
coralman's Avatar
Thanks just urd!
http://www.jeepforum.com/forum/f13/c...-faqs-2863665/
coralman is offline   Reply With Quote Quick reply to this message
Unread 05-11-2013, 03:46 PM   #47
kg6mov
kg6mov's Avatar
Why not upgrade to the V8 tie rod at least while you're doing all this. Seems like a small thing for stronger components.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
kg6mov is online now   Reply With Quote Quick reply to this message
Unread 05-11-2013, 04:08 PM   #48
coralman
its the beam Jim
coralman's Avatar
Mainly because I don't do anything to warrant stronger stuff. I mean the stuff there was all original I believe cept the brakes. I'm 55. If it last as long I probaly wont care much past that point.
Unread 05-11-2013, 07:15 PM   #49
ZeeJay1997
Originally Posted by coralman View Post
I'm just not committed to the wj manifold, apn header, 703's, and magnaflow exhaust just yet.
Well if you decide you not gonna do it, that should clear up some space in your living room.
If my plans work out, I should be rid of the ZJ before the end of the summer. It's getting in pretty sad shape... by my standards at least...
ZeeJay1997 is online now   Reply With Quote Quick reply to this message
Unread 05-11-2013, 08:19 PM   #50
coralman
its the beam Jim
coralman's Avatar
What do you want in its place?
Unread 05-11-2013, 08:57 PM   #51
ZeeJay1997
Something that pulls well behind a motor home. Planning to make move to the four corners area and live a nomadic lifestyle as a precursor to retirement. Trying to transfer.
Unread 05-15-2013, 10:06 PM   #52
Uniblurb
Uniblurb's Avatar
Just got around to reading your finish coralman. Great job and looks really nice! Definitely worth referring other members to!
Best of luck to you Zee and I was going to move out west when younger. Could kick myself for not doing it sooner but it's never too late! Believe I could get off in doing a little gold mining and searching for precious stones.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
-Stalling ZJ? 12 things to check before replacing a sensor; the Dirty Dozen
-Crankshaft position sensor multimeter test. & video of testing.
Uniblurb is offline   Reply With Quote Quick reply to this message
Unread 05-17-2013, 06:05 AM   #53
coralman
its the beam Jim
coralman's Avatar
Well,I learned something about tires in doing this. The new tires were all nice and clean ,but within a few days they developed this brown residue on them. So I scrubbed the stuff off and it came back. It was nasty looking. Come to find out it is a compound they are adding to new tires called an "antizonant". Its seeps out of the rubber as you drive it to prevent oxidation of the rubber. Info said you can't stop it but can minimze by using tire dressing. Went to wally word got some brand called "california pro tire dressing" and it looks good. Not tooo shiny. Another fact I forgot to mention was the niner wheel/tire combo is 8lbs heavier than the original rims and tires. so thats 40 more pounds counting the spare.
Unread 08-22-2013, 06:57 PM   #54
NJ2MDJim
Awesome write-up! Thanks for all the time and effort you put into this. I'm sure it will help a lot of people.
NJ2MDJim is offline   Reply With Quote Quick reply to this message
Unread 08-23-2013, 03:58 AM   #55
coralman
its the beam Jim
coralman's Avatar
Yw!
Unread 12-12-2013, 11:01 PM   #56
9496ZJs
Coralman:
Wow! What a project. Nice work. But you were seriously deprived of the experience of chasing rust around every corner and asking yourself, "hmm. Should I wire wheel that bracket before I reinstall that control arm? Or is the steel too thin to survive?"
Must be nice to work on bare steel.
9496ZJs is offline   Reply With Quote Quick reply to this message
Unread 12-13-2013, 05:58 AM   #57
coralman
its the beam Jim
coralman's Avatar
Thanks! Yeah I have always felt bad for the guys who have to deal with the salt. Jeep could've done more to protest the underside. I think it was RAT who said something about if the salt didn't get you the A/C draining into the frame would. Currently working on solving that among other piles. This weekend is leaking tstat gasket, coolant temp sensor, on the WJ, it never ends.
Unread 12-13-2013, 03:58 PM   #58
shaban
In here, ZJ bodies last pretty much forever, they're going to junkyards after either hitting a kangaroo/other car, or after 42RE tranny crapping out.
However, I've seen a few XJ's with rust around the windshield frame.
Plus sometimes rust gets'em it the owner lives on a coast too.
shaban is offline   Reply With Quote Quick reply to this message
Unread 12-13-2013, 04:29 PM   #59
coralman
its the beam Jim
coralman's Avatar
Back in the day,lol, when vehicles were allowed to run the coast in northern fla the rust got stuff too. Used to be a guy with a halftrack that practically lived on the beach. That was along time ago.
Unread 06-27-2014, 06:49 AM   #60
jeepjeepster
Sorry to bring this post back from the semi dead but I must comment on a wonderful job. Thoroughly enjoyed reading through it and seeing a job well done. Hate that you had to have it towed after doing so much work.
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline   Reply With Quote Quick reply to this message
