cooling system problems , water pump and thermostat replaced . no heat. - JeepForum.com
post #1 of 5 Old 10-25-2009, 07:24 AM Thread Starter
natesxj
i parked it way up on a hill , to blee any air out after replacing my thermostat and water pump. ran it for like 45 minutes of different tricks to remove air lock.
it seemed like the water was only trickling through the heater hose. no heat.
engine only warms up to 1 notch above the coldest mark on the factory guage. when the pump was bad it was running 75% of the guage lol making heat before.
i thought there was an air lock preventing heat but then why would the ENGINE temperature stay so darn low? not harmfull but i cant defrost my windows very well.
so we hooked a garden hose into the heater hoses feeding water through the core and now i have SOME heat , takes a while to warm up.
thermostat and water pump are brand new. any sujjestions would be great.
- my last post about the leak i couldnt find was out of the weep hole on the bottom like everyone was telling me , it leaks down and sneaks behind the timing mark thing above the crank pulley apearing to "not come from the pump" when it actually does. and can poor very quickly .
natesxj is offline
post #2 of 5 Old 10-25-2009, 08:43 AM
McGR
2007 XK Commander
Because you say that the engine isnt getting up to normal operating temp, it would seem that somethings amiss with your new thermostat. You may want to pull it and test it in some water heated over a stove.
McGR is offline
post #3 of 5 Old 10-25-2009, 08:46 AM
Zembonez
Make sure you have the right thermostat and it is functioning properly (yeah obvious I know). I always fill the system through the heater hose when I refill it. It verifies that the heater core is full and removes air from the system.
Zembonez - XJ ADDICT -
Originally Posted by Cowboy Cadillac
Canada has 4 seasons...Almost winter, winter, still winter and road construction
Zembonez is offline
post #4 of 5 Old 10-25-2009, 08:55 AM Thread Starter
natesxj
thanks for the help guys im going to go put the old thermostat back in and see if theres a dfiference its a $1.50 for the gasket so no big deal right lol.
ive got some RTV here just incase i tear the gasket removing it.
ill let u know what happens , thsi would be my third bad part ive bought and had to exchange lol... lots of DOA stuff
natesxj is offline
post #5 of 5 Old 10-25-2009, 09:49 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
I would just buy another thermostat and install it... its a ~$4 part anyway
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
Cooling system and lack of heat Texas98ZJ ZJ Grand Cherokee Forum 16 02-04-2010 09:21 PM
New Water Pump/Thermostat, now no heat tfgnt16 ZJ Grand Cherokee Forum 19 12-11-2009 08:49 PM
Air in cooling system goes away with heat on? lma1973 ZJ Grand Cherokee Forum 10 09-28-2007 03:07 PM
Flushed Cooling System- No Heat?? Myrtle Beach ZJ Grand Cherokee Forum 9 04-16-2005 02:56 PM
Bad Water Pump or Thermostat? dpierson ZJ Grand Cherokee Forum 19 12-23-2004 10:41 PM
