cooling question.... - JeepForum.com
post #1 of 5 Old 08-04-2003, 03:43 PM Thread Starter
tetatdo
1994 ZJ
Hi. I have a 94 ZJ 4.0 and I recently went through and changed all the hoses. I drained the radiator, replaced all four houses and the thermostat and put it all back together. I even put in a 180 Deg thermostat.... the car seems to run cooler according to the guages but Im a little bit skeptical.... Every time I feel the upper radiator hose, it is not under pressure.. i can squeeze it all the way till my fingers touch. I can even do this when its hot and its still not under pressure. The lower radiator hose seems to only be under a slight more amount of pressure, but even that isn't much... Did i do something wrong? I seem to remember with the old hoses and thermostat that there was more pressure in the system... Should I not drive around the car? Is the guage lying to me? is there a coolant blockage somewhere? or air in the system? I think i burped the radiator right, I just kept filling and squeezing the upper hose and letting air out.. I don't want to ruin the car.. I hope its running okay.
tetatdo is offline
post #2 of 5 Old 08-04-2003, 04:07 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Is the resevoir for the fluid full? Add more fluid and see what happens.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 5 Old 08-04-2003, 04:17 PM Thread Starter
tetatdo
1994 ZJ
yeah, the reservoir is full
mind you, the car doesn't run hot.. Which is why its baffling me.. I mean the temp guage says its running kinda cool. but the hoses aren't under pressure. I get the feeling something's wrong
tetatdo is offline
post #4 of 5 Old 08-04-2003, 04:37 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
That's weird. When I replaced all the rad fluid, I just kept adding until the rad was full. Then, I squeezed the top hose and it filled allowing me to pour more into the rad.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #5 of 5 Old 08-04-2003, 05:00 PM Thread Starter
tetatdo
1994 ZJ
yeah I was doing the exact same thing. When i squeezed the top hose, air would bubble out... I did it till i got no more air out of the rad and i capped it..
The upper hose gets a little bit of pressure, and it certainly gets hot when the car is running, but its just not under pressure
tetatdo is offline
electric cooling fan question? 2wdcherokee ZJ Grand Cherokee Forum 5 10-29-2009 03:10 PM
Cooling question ledfoot02 ZJ Grand Cherokee Forum 1 10-26-2009 10:59 PM
Cooling Fan Question '00 WJ 4.7 Drysdale ZJ Grand Cherokee Forum 17 07-18-2009 10:44 PM
07 GC cooling question dalefan4lyf WK Grand Cherokee & XK Commander Forum 1 01-29-2009 08:42 PM
cooling system question lma1973 ZJ Grand Cherokee Forum 14 08-19-2007 05:00 PM
