cooling problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > cooling problem
ECGS JK Dana 60 Bolt In Rear DiffGEARSHADE Pocket Tops in stock and available at ROCKRIDGE G2 Disc Brake Conversion Kit for Jeep Wrangler YJ TJ LJ Ch
Unread 07-23-2014, 10:00 PM   #1
radrfan1959
cooling problem
I need a little help!!! my 1993 grand Cherokee straight 6 heats up after about 1 hr of driving but only stop and go traffic, when driving above 30mph its fine keeping below 180 degrees. flushed system replaced all anti freeze and even changed thermostat with oem 195degree. driving around town normal traffic no problems only stop and go after awhile driving. any suggestions radiator, weak water pump, belt bad thermo also have make shift cap on recovery tank help!!!!!!!
radrfan1959 is offline   Reply With Quote
Unread 07-23-2014, 10:44 PM   #2
Pugulis
Bad fan clutch.
[_][]☺[][][]☺[][_] 96' Grand Cherokee Laredo 265,000 miles and still going strong.
Pugulis is offline   Reply With Quote
Unread 07-24-2014, 05:08 AM   #3
jeepjeepster
^This
1994 ZJ-I6 w/209,100 mi
1998 ZJ 5.9 w/64,800 mi Slate Black
2004 KJ w/85,000 mi
jeepjeepster is offline   Reply With Quote
Unread 07-24-2014, 06:28 AM   #4
firsttimeZJ13
How hot is it getting?? If your thermostat is a 195, you should expect it to run around there. Fan clutch is always a possibility.
1995 ZJ, 5.2L, NP249, stock suspension, e-fan, CAI, engine needs work!! Plan on lift and tires when money finds its way here...
firsttimeZJ13 is offline   Reply With Quote
Unread 07-24-2014, 11:34 AM   #5
Uniblurb
Uniblurb's Avatar
Not sure what kind of make-shift cap you made for the coolant reservoir/tank but it should not be taped on air-tight and the OE cap isn't air-tight either! Make a mark on the tank at coolant level after it's been sitting overnight then check to see if the coolant level has risen once hot. As the engine sits overnight, and the coolant cools down, a vacuum is created in the cooling system which draws coolant in from the reservoir. Then once it heats up to normal operating temps the coolant expands which gives you a higher tank level. If the coolant level is not changing then check to make sure the make-shift cap isn't on too tight and rubber hose between tank/rad filler neck isn't clogged. If the level hardly changes, and if the reservoir cap isn't air tight, while your hose is open/not clogged, then your rad cap could also be faulty in not opening up to let the coolant pass.
But if the coolant level is moving up/down good depending on cool/hot then I'd also suspect the fan clutch as others mentioned. With a 195 degree thermostat I've always used my normal operating temp is right around 210, or a hair under, which is normal spec. Good luck!
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
-Stalling ZJ? 12 things to check before replacing a sensor; the Dirty Dozen
-Crankshaft position sensor multimeter test. & video of testing.
Uniblurb is offline   Reply With Quote
Unread 07-24-2014, 12:51 PM   #6
PolkaPower
Stock cap is 18 or 19lbs? I forget. It's one of those.
PolkaPower is online now   Reply With Quote
Unread 07-24-2014, 02:13 PM   #7
Scopez
1994 ZJ
Originally Posted by polkapower
stock cap is 18 or 19lbs? I forget. It's one of those.
18
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is online now   Reply With Quote
Unread 07-24-2014, 02:31 PM   #8
radean84
Sounds like fan clutch to me too. May be a good time to remove the fan/shroud and switch over to electric for about $80. My Jeep was getting hot in 90-100 degree weather with the AC on but after doing the Taurus fan and Supercooler she stays just shy of 210 no matter how hot it is outside or how long I'm sitting. That's without using the high speed, just low speed with a typical 40 amp relay.
www.ProjectZJ.com Build Sheet and Videos
radean84 is offline   Reply With Quote
