cooling issues - JeepForum.com
post #1 of 8 Old 03-31-2004, 01:07 PM Thread Starter
greenmachine99
greenmachine99's Avatar
cooling issues
hello, I have a 95 GC with a 318 ci. It fails emissions because it wont get hot enough. The hottest it runs is about 175. I just replaced the thermostat with a stock 195 degree, replaced the coolant tempeture sensor and air intake tempeture sensor and it still doesnt heat up. Anyone have any ideas? I need to get this fixed, i only have about 2 more weeks before its due in the emissions place again, and with it running cool it will fail. Thanks.
greenmachine99 is offline
post #2 of 8 Old 03-31-2004, 01:17 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Mine runs hotter than that. I'll have to search around for an answer.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 8 Old 03-31-2004, 03:10 PM
Meerkat
Hotter spark plugs
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #4 of 8 Old 04-01-2004, 07:06 PM Thread Starter
greenmachine99
yea, i know, its supposed to run @195. any ideas?
post #5 of 8 Old 04-02-2004, 06:30 AM
Meerkat
Seriously, have you tried hotter spark plugs? They will burn more of the fuel, and lower your emissions, perhaps enough to pass.
Warren
Meerkat is offline
post #6 of 8 Old 04-02-2004, 07:45 AM
97RedBird
2009 MK Compass
Running rich would cause you to run cool as well. If the O2's are getting old they will cause your Jeep to run a little on the rich side. Running lean will cause more heat. How does your MPG look?
97RedBird is offline
post #7 of 8 Old 04-02-2004, 01:01 PM
greasefingers
greasefingers's Avatar
1994 ZJ
The tick-mark just before 210 F = 182.5 F. Your temperature dial should in-between these two. Mine never is. Its always at 182.5 F with a 195 F thermostat. But thats not important. What is important is that the CTS sends the correct information to the PCM. Since you just replaced your CTS, I would suspect that it is sending the correct information. I would not trust the read out of the dashboard display to be very precise. If you curious enough, you can check the resistance of the CTS at different temperatures using a pot of water on a stove with a thermometer. There are values for resistance vs temperature, listed in the Haynes manual. The best part about this test is its free. If you know how to plot graphs in Excel, then it does not matter what temperatures you choose. Simply plot your measured values and then co-plot the values listed in the Haynes manual. You will see if they are close or not. I would start if checking O2 sensor first.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #8 of 8 Old 04-02-2004, 03:24 PM Thread Starter
greenmachine99
Its getting about 15 mpg, so i dont think its running all that rich because thats pretty average.
cooling issues twice in 2 days!! argh lma1973 ZJ Grand Cherokee Forum 14 09-22-2009 07:44 AM
03 grand cooling issues. Wolfhope ZJ Grand Cherokee Forum 3 09-08-2009 02:47 PM
Hydraulic Cooling Fan Solenoid Issues slush ZJ Grand Cherokee Forum 4 06-23-2009 07:36 PM
1998 5.9 Cooling Issues Rhineaux ZJ Grand Cherokee Forum 5 04-08-2007 09:47 PM
Gc 4.7 Cooling Issues- Help!!!!! frogbit ZJ Grand Cherokee Forum 29 08-07-2006 08:33 AM
