Cooling fan for the 5.2 - JeepForum.com
post #1 of 14 Old 07-08-2011, 09:56 AM Thread Starter
JeeperV8
Ok I have some choices to make. Some idiot ran a red and totaled the gc and I'm trying to get it going again on a non existent budget.
So heres my question, what is the best electric fan for my truck, what do they cost, and were do you get them?
I know some of the 5.9 came with an arctic fan stock, would this be a good option to look into as well?
JeeperV8 is offline
post #2 of 14 Old 07-08-2011, 10:10 AM
KingtheZJ
taurus efan. there are writeups about the swap and wiring everywhere
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #3 of 14 Old 07-08-2011, 07:13 PM Thread Starter
JeeperV8
How much do those run?
JeeperV8 is offline
post #4 of 14 Old 07-08-2011, 07:22 PM
blackjack12982
1994 ZJ
Get them in a JY, or buy one off of eBay. If you were closer to me, I'd cut you a deal on one of them.
The most expensive part of the swap is your controller. I used a Delta Current Control unit that ran probably $80, IIRC. It's really nice!
There are cheaper controllers, just depends how you want it controlled.
blackjack12982 is offline
post #5 of 14 Old 07-08-2011, 07:44 PM Thread Starter
JeeperV8
Is the taurus efan off a ford taurus or is that just the brand name?
JeeperV8 is offline
post #6 of 14 Old 07-08-2011, 07:59 PM
blackjack12982
1994 ZJ
It's off of the V6 Ford Taurus/Contour
http://www.jeepforum.com/forum/f13/f...ght=taurus+fan
http://www.jeepforum.com/forum/f13/a...-pics-1003862/
post #7 of 14 Old 07-09-2011, 02:48 PM Thread Starter
JeeperV8
I see that the taurus fan wire up was on a manual switch, its there a controller for it to ruin automatically?
JeeperV8 is offline
post #8 of 14 Old 07-09-2011, 02:49 PM
blackjack12982
1994 ZJ
Yep!
post #9 of 14 Old 07-10-2011, 10:15 AM
tcar
is there a controller for it to ruin automatically?
Ruin... Freudian slip? Funny...
Not criticizing, I misspell stuff 2.
You should get a thermostatic controller.
With a manual switch, if you get distracted and forget to switch on... big oops.
SO, what's wrong with using an original fan... they work fine.
00 Limited 4.7 V8 SelecTrac
94 Limited V8 SelecTrac
98 5.9 Platinum
95 Limited V8
tcar is offline
post #10 of 14 Old 07-10-2011, 10:49 AM
vegasZJ
I did a efan swap to my truck. When the ac is on it over heats. When you turn it off temp drops instantly. Also new water pump thermostat hoses. Granted its 110 degrees here,but didn't have this issue with the clutch fan. Any help
When in doubt throttle out!
vegasZJ is offline
post #11 of 14 Old 07-10-2011, 10:52 AM
blackjack12982
1994 ZJ
Is it a 2 speed fan with the high speed engaged for AC automatically?
post #12 of 14 Old 07-10-2011, 11:05 AM
vegasZJ
Its a one speed fan. Moves 3600 cfm. My buddy is running the same one with no issues.
vegasZJ is offline
post #13 of 14 Old 07-10-2011, 09:49 PM Thread Starter
JeeperV8
What are some websites I could find the controllers on?
JeeperV8 is offline
post #14 of 14 Old 07-11-2011, 08:24 AM
tcar
How old is your radiator?
98 5.9 Platinum
95 Limited V8
tcar is offline
