Coolant Temp Sending Unit - to dash/gauge (not computer) - JeepForum.com
post #1 of 17 Old 07-10-2011, 08:37 AM Thread Starter
Oxenhandler
Replacing Coolant Temp Sending Unit - to dash/gauge (not computer)
The change out described in this thread was on a 1995 Jeep Grand Cherokee, 6 cylinder, 4 liter engine, here known as a ZJ.
The 95 has two temp sensors, one in the front of the engine compartment, on the t stat for the computer and one on the back of the head for the dash. The one on the back of the head is the one to the gauge.
The 96-98 have the gauge run by the pcm (powertrain control module, aka, computer) with no need for a second sender.
Yesterday, TheHalfWit on this forum wrote and I paraphrase, "But the 93-95 4.0's have a second sender on the very back of the block, under the wiring for the injectors, 3" from the firewall and it is a ***** to change."
Here's where you'll find the temp sensor/sending unit/switch for the gauge, follow the orange arrow (a).
Oxenhandler is offline
post #2 of 17 Old 07-10-2011, 09:03 AM Thread Starter
Oxenhandler
It is hard to see and harder still to change out because there is so little clearance above and beside it, add to that, that the sensor itself is extremely fragile and easy to break.
Here’s another view of the temp sending unit in place. It is white. (b)
post #3 of 17 Old 07-10-2011, 09:11 AM Thread Starter
Oxenhandler
The factory original stopped working. It was broken, probably snapped by a mechanic's tool during a tune-up. Removing it, I broke the white ceramic top completely off because I didn't have the deep socket tight against the nut when I cranked it. Here’s what I was left with, the shaft, the threads and the nut (c)
post #4 of 17 Old 07-10-2011, 09:18 AM Thread Starter
Oxenhandler
To replace it I bought a Duralast brand temp sending unit from Autozone, part number TU236 Temp Switch. But I over tightened it, installing it, and snapped off the white ceramic top AND the brass nut, leaving the brass shaft and threads imbedded in the engine.
Here you see the factory original with the white top snapped off, the Duralast brand with the brass shaft/tube broken off and the Duralast part box. (d)
post #5 of 17 Old 07-10-2011, 09:25 AM Thread Starter
Oxenhandler
Here's what the sending unit port looks like with the brass shaft/tube and brass threads of the sensor imbedded in it. (e)
post #6 of 17 Old 07-10-2011, 09:27 AM Thread Starter
Oxenhandler
To extract it I used a 7/16" screw extractor (f)
post #7 of 17 Old 07-10-2011, 09:29 AM Thread Starter
Oxenhandler
I tapped the tip of the extractor into the hollow tube of the sending unit and turned it with a wrench. It was difficult as the swing room for the wrench was only an inch or two. (g)
post #8 of 17 Old 07-10-2011, 09:31 AM Thread Starter
Oxenhandler
But I did get it out. (h)
post #9 of 17 Old 07-10-2011, 09:39 AM Thread Starter
Oxenhandler
I bought another sender, NAPA part No. TS6685 and installed it gently. Even so, I broke it. But not so much that it doesn't work. It works great!
The trick is not to over tighten as the nut and tube are thin, hollow, brass and not to crank on the ratchet unless you are certain the deep socket is all the way over the nut. The socket will twist the white part independent of the nut and break it if you do not have the socket all the way over the nut and the hollow, brass nut will twist off the hollow, brass threads if you over tighten.
Note: each of these senders required a different size deep socket, 11, 12 and 14mm.
Here you see the NAPA box, two broken senders, one intact sender (the one that's in my Jeep now!), and the screw extractor (i)
post #10 of 17 Old 07-10-2011, 09:49 AM Thread Starter
Oxenhandler
Here's the sending unit and the brass shaft that was once part of it (with the screw extractor still inside it). Ever wonder what's inside the temp sender? A steel spring inside a paper tube. (j)
post #11 of 17 Old 07-10-2011, 09:56 AM Thread Starter
Oxenhandler
The End
post #12 of 17 Old 07-10-2011, 04:43 PM
TheHalfWit
I know this isn't strictly related to the thread, but its a mistake I managed to do while I was changing the sensor.
That crooked hose is the PCV hose, and it looks like you knocked it loose like I did. The easiest way to check for that is just to listen for a hissing. In all likelihood you'll need a new grommet for it, so that it will seal up tight.
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #13 of 17 Old 07-30-2011, 05:26 PM
JeeperV8
If this sensor is bad what will happen?
JeeperV8 is offline
post #14 of 17 Old 07-31-2011, 06:44 AM Thread Starter
Oxenhandler
You won't be able to monitor your coolant temperature. So you won't know you're overheating until you see steam escaping from under your hood by which time it may be too late to prevent costly, repairable harm to your radiator and engine. For starters, your radiator may crack.
post #15 of 17 Old 07-31-2011, 08:49 AM
JeeperV8
Got ya, how do you know when the sensor hours bad on you
JeeperV8 is offline
Trans Temp Gauge install w/factory sending unit iflypa28 ZJ Grand Cherokee Forum 7 07-13-2013 01:05 AM
ZJ Fuel Gauge sending unit? but DIC says other wise... porrsher ZJ Grand Cherokee Forum 5 10-26-2010 05:03 PM
Temp sending unit where is it? -cAcHe- ZJ Grand Cherokee Forum 5 04-01-2008 05:05 PM
Oil Gauge Sending Unit rebel517 ZJ Grand Cherokee Forum 30 01-29-2008 08:57 AM
Temp Sending Unit Fix Laredo Joe ZJ Grand Cherokee Forum 2 09-16-2005 12:51 PM
