Coolant Smell on 2002 Grand Cherokee – No heater core symptoms - JeepForum.com
post #1 of 3 Old 03-04-2010, 01:30 PM Thread Starter
GS Audio
This one is a mind boggler……
Got this Jeep in 2008 with a bad heater core. Bought the heater treater kit, new core, and new evap….figure I’d replace all in one shot while in there. This was done December 2008.
Core went bad again after 7 or 8 months and was replaced free in September 2009. The coolant smell stuck around though. Heat works great, defrost does too with no residue on the window. When I step out of the Jeep after a drive, I smell the coolant more around the front/engine area.
Coolant level is fine, no smoke or smells from exhaust, oil is clean, so I’ve ruled out head gasket, and there are no leaks in the driveway, garage, or parking spot at work.
Could there be some microscopic leak at one of the hoses or radiator? And then the heater sucks the smell from the engine bay into the vehicle?
It just doesn’t add up what could be causing the smell…..
Anyone?
Thanks!
The current line-up:
2002 WJ Overland 4.7HO
1996 Jeep Cherokee Sport (AX-15 :D)
2007 Chevy Trailblazer SS 6.0 V8
GS Audio is offline
post #2 of 3 Old 03-04-2010, 05:05 PM
Double E
Double E's Avatar
How about a pinhole leak in the system such as this?
http://www.jeepforum.com/forum/f13/4...-avail-971799/
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 3 Old 03-04-2010, 08:01 PM Thread Starter
GS Audio
Don't think this is my issue.....no missing coolant, not one drop. I do smell the coolant in that general area.....so maybe we're onto something?
What are typical signs of a failing water pump (if any?)?
GS Audio is offline
Replacing Heater Core on 99 Jeep Grand Cherokee ralphlassiter ZJ Grand Cherokee Forum 5 07-05-2014 10:34 PM
Possible coolant smell from heater after whiledrive ZJcrawler45 ZJ Grand Cherokee Forum 10 01-28-2010 01:05 PM
02 grand cherokee limited 4.7HO heater core question Jedlindberg ZJ Grand Cherokee Forum 4 12-25-2009 07:14 AM
Blown heater core in my son's 2002 JGC Jerry Bransford ZJ Grand Cherokee Forum 8 05-23-2008 12:39 PM
95 Grand Cherokee...sweet smell...coolant light..etc.. TheZaZ ZJ Grand Cherokee Forum 6 11-08-2006 04:00 PM
