Coolant Sensor Bad/VIC removal - Page 3 - JeepForum.com
 3Likes
post #31 of 90 Old 03-18-2012, 12:43 AM
j.love
j.love's Avatar
1994 ZJ
wiring harnesses are different for non VIC vehicles.
David.
94 ZJ laredo 5.9 V8 swap D44a posi
Originally Posted by ratmonkey View Post
I wouldn't drive down a driveway on that.
''If we do everything right, if we do it with absolute certainty, there's still a 30% chance we're going to get it wrong.''
Joe Biden
j.love is offline
post #32 of 90 Old 04-14-2012, 05:48 PM
cnaples
Worked!
I just swapped out my TC for the 249 and had to take out my VIC to swap the red and black wires. I figured while the VIC was out I would pop it open and try to get rid of the annoying beeps. The solder joint didn't even look bad but I re flowed them and sure enough it worked! Thank you for the awesome write up!!!
cnaples is offline
post #33 of 90 Old 05-06-2012, 06:52 PM
johng1
THANK YOU for posting the details for this fix. After resoldering the target point on the circuit board on my 97 GC the problem is history. What a relief !!! Many thanks ! ! ! ! !
johng1 is offline
post #34 of 90 Old 07-19-2012, 10:15 PM
dalemetal
Worked great for me too, thank you so much. Yes, that clip did near ruin me, and fight to get it back together.
Thanks again!
dalemetal is offline
post #35 of 90 Old 07-31-2012, 09:24 PM
SkipJunkman
My first soldering and my first post on Jeep forum!
I'm afraid to speak too soon, but I did this and it seemed to work. Normally the code pops up as soon as I turn on the jeep, and if not soon after. I did a test cruise and so far so good.
Too bad I followed logic at first and replace both coolant sensors.
All together I got it done in about an hour, including a break to scratch my head over the circuits parts. I don't know what to look for as far as faulty soldering jobs, but everything looked pretty uniform. I went over it anyway and here we are. And as far as the clip, push the passenger side toward where it normally sits, and pull near the VIC. It was pie on mine.
If the message pops back up tomorrow on my way to deliver sandwiches freaky fast, I'm going to jump through my windshield.
Thanks x1000.
SkipJunkman is offline
post #36 of 90 Old 07-31-2012, 09:41 PM
KoreaZJ
1994 ZJ
Good job SkipJunkman... and welcome to JF!
Can't always see a fractured solder joint, even with a magnifier.
Dull or corroded connections are suspect.
Don't use too much heat or hold it longer than necessary to reflow the solder.
KoreaZJ is offline
post #37 of 90 Old 07-31-2012, 10:18 PM
Canyon411
Since this thread is back up, check out the white zj toward the top with the polished ravine wheels!!
Canyon411 is offline
post #38 of 90 Old 08-31-2012, 07:03 PM
gothchick
Thanks again to the OP and all the great info in this thread. Reflowed the solder joints on the VIC, problem fixed. Damn, that thing was driving me nutz. Still need to swap the plugs for the TC swap we just finished. Props. Thanks again!
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
post #39 of 90 Old 09-04-2012, 10:42 AM
rallycom
2006 KJ Liberty
Changed VIC different light?
Great write up Thanks!
Since I usually solder with a bernzomatic tourch (or at least it looks like I do) I opted to pick up a used VIC before trying the fix. Pluged the used unit in & like magic the 'coolant sensor bad' & 'service 4wd switch' warning messages went away........for a week! Now the 'coolant sensor bad' message is back but instead of the display showing the lighted line by the radiator, it now displays a retangular light in the engine compartment. I was told the replacement unit came from the same year & trim level as my 1996 Grand Cherokee Laredo. Anyone run into anything similar?
I just finished soldering the original one but haven't tried it yet.
Thanks
Rich, N2ZKX
Black 1996 ZJ 260,000 mi & running strong
Black 2006 KJ 121,000 mi just getting broken in
rallycom is offline
post #40 of 90 Old 09-04-2012, 10:57 AM
KoreaZJ
1994 ZJ
My '94 VIC rectangular box in the engine bay means the engine oil level is low. Part of the optional oil level sensor feature mounted in the side of the oil pan.
KoreaZJ is offline
post #41 of 90 Old 09-04-2012, 11:04 AM
dpjag
Great fix... did mine on the 98GC over the weekend
dpjag is offline
post #42 of 90 Old 09-04-2012, 01:02 PM
rallycom
2006 KJ Liberty
Oils good
Thanks for the response, I checked the oil right away & it's fine. I'm going to put the unit I soldered in tomorrow & see what strange things happen then.
Thanks
Rich, N2ZKX
rallycom is offline
post #43 of 90 Old 11-20-2012, 03:43 PM
MYNUTOY
UNBLIEVABLE!! Great write up Great pics.problems gone!! Can anyone help with the heater control head unit I pulled it out and when I put it back in the leds that indicate where the air is directed arn't lighting up all I did was unplug it and plug it back in and they wont light everything else in the head unit works fine anyone???worked before I removed it!!Thanks
MYNUTOY is offline
post #44 of 90 Old 01-22-2013, 04:15 AM
jeffcox
1996 FSJ Cherokee
Collant Sensor
I'm really new to this site. Thank you guys for the outstanding support on just about every issue a person could encounter. I'm going to attempt this soldering fix. It appearing more time consuming than anything. Working and the single digit temps are slowing me down a little. Eventually I'll get to my sensor problem. I also have what I feel is my wheel bearings going bad. I assume these are just like any other bearings r and r. If there is any other special things I should know, please hollar at me. Thanks for everything.
jeffcox is offline
post #45 of 90 Old 03-25-2013, 11:13 PM
smcalpac
Just bought a 98 ZJ Limited with this problem. Previous owner said they had the sensor replaced and checked out. Mechanic couldn't figure it out....guess he didn't GOOGLE the issue. 30 minutes later, I've got the issue fixed, thanks!
I'm here because
my little girl
doesn't need her dad
on two wheels anymore!
Camoflauge, camoflauge, I disappear when I pull out of my garage!
PM me for LED light bars and HID off road lights
smcalpac is offline
high voltage o2 sensor/bad coolant sensor Jh24k WK Grand Cherokee & XK Commander Forum 1 07-19-2013 10:22 AM
coolant sensor bad?? krawlin ZJ Grand Cherokee Forum 7 06-17-2011 10:35 PM
Coolant Sensor Bad! Paris Holley ZJ Grand Cherokee Forum 3 06-17-2011 03:00 PM
coolant sensor bad. rallyjeep_11 ZJ Grand Cherokee Forum 7 06-17-2011 02:58 PM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 03:52 PM
