"Coolant Sensor Bad" FINALLY FIXED!!!! - Page 9 - JeepForum.com
 2Likes
post #121 of 141 Old 08-05-2013, 10:24 PM
Snowfan2
Originally Posted by KoreaZJ View Post
For testing... Coolant Sensor can be replaced with a 3.3KΩ resistor. If the message is still there, then likely VIC solder joint(s). Fractured solder joints may not be easy to see, even with a magnifier.
I found several fractured solder joints, the main ground pin solder was worst. I resoldered every pin in both rows.
Great pic KoreaZJ, thanks.
Fixed mine yesterday, no more beeps. Nice.
Snowfan2 is offline
post #122 of 141 Old 09-25-2013, 07:21 AM
jmcgxx
2013 WK
Coolant Sensor bad
One more huge thanks to phild328 for his help with repair of my VIC solder connection.
jmcgxx is offline
post #123 of 141 Old 10-08-2013, 02:28 PM
coldiron44
Coolant sensor light and alarm
For my '97 GC, phild328 was on the money. I followed his directions and sure enough, found bad soldering in several connections including the one for the coolant sensor in the overflow tank. Checked the resistance at the places noted before taking out the VIC. A few cents worth of solder and about an hour of work and it's fixed. Thanks.
coldiron44 is offline
post #124 of 141 Old 10-08-2013, 05:13 PM
Smokey1r
Its always a good idea to just reflow all of the pins on that connector, that way the joints are all refreshed and ready to go for another decade or more.
Smokey1r is offline
post #125 of 141 Old 10-17-2013, 01:15 AM
TomTechy
For my 1996 Grand Cherokee, Thanks to phild328 for this solution, it solved my bogus and annoying "Coolant Sensor bad" message. The solder joints on 4 pins of the my connector were just slightly fractured as in the picture provided by KoreaZJ. I re-flowed solder on all of the pins on that connector... no more bogus alarms.
TomTechy is offline
post #126 of 141 Old 03-11-2014, 08:54 PM
97LMTDORVIS
Hope this works some times I just want to rip out the VIC and hammer it to death gonna check it all out in the a.m.
97LMTDORVIS is offline
post #127 of 141 Old 03-11-2014, 09:02 PM
kg6mov
Hears the voices
kg6mov's Avatar
Yep, I did it to the niner last I had the dash apart, you'll be able to see the bad solder joints.
kg6mov is offline
post #128 of 141 Old 04-22-2014, 08:36 AM
ZJJay
ZJJay's Avatar
Yep, it's fixed!
I finally made time to remove the VIC. I had a friend reflow the solder connections as I didn't have a soldering iron small enough. (Darn, those pins are SMALL!) No error message since. Thanks to the OP and everyone else for their input.
'96 ZJ, 4.0L, 42RE, NP242, stock D30 and D35-LS w/ 3.73, 4-1/2" lift, 32" BFG ATs, Magnaflow, JKS track bars and disconnects, spare tire carrier, Optima red top, ROLA roof rack, KC SlimLite driving lights, CB and Yaesu ham radios, GPS
ZJJay is offline
post #129 of 141 Old 04-22-2014, 10:27 AM
jeepjeepster
Im not entirely sure if mine had cracked solder joints but I resoldered all of the joints. Mine ended up actually being a bad coolant sensor.
Does anyone know why the FSM shows the 4.0 having an oil level sensor but it doesn't? That would've been kinda neat.
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline
post #130 of 141 Old 06-30-2014, 09:16 AM
Tailspin57
Originally Posted by Kruzin View Post
Doncha just love it when a 3 year old thread get resurected, and ppl act like it's new info
Some people act like its new info because:
-they just bought a Jeep
-have the same problem
-surfed the web for a solution
-joined this wonderful form
-found a solution
-and like me, it is the first time they visited the form making it “new info” to me
PS you misspelled “resurected” (you forgot an “r”)
Tailspin57 is offline
post #131 of 141 Old 06-30-2014, 12:17 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Amen
Originally Posted by HighLonesome
coralman is offline
post #132 of 141 Old 07-01-2014, 08:38 AM
jeepjeepster
I think its a good thing that people do some research. I often times enjoy reading old threads when people bring them back from the dead. More so if its a good write-up or build thread.
Its a nice surprise to have a 10 page build thread popup to read through. Almost like an accidental fart that brightens up your day. Pop, there it is.
2004 KJ w/90,300 mi
post #133 of 141 Old 07-01-2014, 09:08 AM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
This post brightened up my day. I'm vehemently opposed to retaining the VIC, but this thread is a good resource for people that don't feel the same way I do.
In the garage: M1 4bbl
McCloudsZJ is offline
post #134 of 141 Old 09-21-2014, 12:51 PM
TerryMK
Thanks for the info
I've had this problem intermittently for several months. I found there were 5 solder posts on the connector that had visible fractures. I also had a surface month resistor that had visible corrosion on the solder. I re-flowed all the connector posts and the resistor and the problem is gone.
A couple years ago I had a problem with the dash lights going out intermittently. This turned out to be a similar solder fracture problem on the headlight/dimmer unit on the left side of the dashboard.
TerryMK is offline
post #135 of 141 Old 12-16-2014, 01:58 PM
Venoom44
where is the coolant temperature sensor for grand Cherokee 201
Venoom44 is offline
"Coolant Sensor is bad" jhillstead ZJ Grand Cherokee Forum 4 07-02-2009 10:18 PM
96 GC. "Coolant Sensor Bad", Which sensor? seanf ZJ Grand Cherokee Forum 2 07-14-2007 04:16 PM
"Coolant Sensor Bad" seth586 ZJ Grand Cherokee Forum 5 06-21-2007 11:35 AM
"Coolant Sensor Bad"?? on '96 ZJ 5.2 oneillsean ZJ Grand Cherokee Forum 16 09-17-2006 12:14 PM
"Coolant sensor bad" Rock1127 ZJ Grand Cherokee Forum 1 10-01-2005 09:17 PM
