"Coolant Sensor Bad" FINALLY FIXED!!!! - JeepForum.com
 2Likes
post #1 of 141 Old 07-08-2005, 05:43 PM Thread Starter
phild328
This is for a 96 Grand - others may be different or not.
Ok, like others I had the annoying "Coolant sensor bad" message on the vic most of the time. And the beeping while you drive - you think a door opened up or something. I've been working on fixing it for what seems like forever. First I didn't know much about the jeep and had no resources. So the coolant level sensor was replaced along with the coolant temp sensor for the PCM.
So the truth is: This message is generated by the coolant level sensor. It is directly wired to the VIC and the VIC is the only thing that uses it. So it really doesn't matter at all. It is just a dumb warning light.
Ok, so how do you fix. I'll bet most of the problems are exactly like mine, but I'll go over the easy stuff first. And Jeep should pay for it because it is a shotty manufacturing flaw. But before I reveal the secret, lets make sure your problem isn't a simple one.
Take the coolant level sensor out and unplug it. First test the sensor. Put an ohm meter accross it and when you push up on the float (as if there is plenty of coolant) it should read 3.3K ohms - or close to, mine is 3.2K. Then let the float drop and you should get closed condition (near 0 ohms).
Now put the ohm meter on the connector from the jeep. First connect it to the black wire terminal. And put the other side of your ohmmeter to a good ground (like the battery term). Should be close to 0 ohm.
Put the sensor back together and plug it in. Give a spray of contact cleaner while you are there. Under the drivers dash, there is a plastic cover near the ODBII connector. Pop it off. There is a orange and white connector that is fairly large, it has 20 wires I believe. Pull it out and find the pink with black stripe wire (same color as at the coolant sensor). Measure resistance between it and a good ground. It should be 3.3Kohm (as long as you have enough coolant in your reserve tank). Spray with contact cleaner and put back together if all is good.
Of course if any of the above is bad, fix the wiring or the sensor. But my guess is it is good. So here comes the fun part.
Tear apart the dash and remove the VIC. Look somewhere else for a dash removal inst. Basically remove the glove box and the panel around it and the panel around the VIC, with two screws behind the ash tray.
Unplug the VIC and take to the bench. Open it up (need torx bit). Get the circuit board out. On the connector - look for your pink with black stripe wire and match to the pin on the circuit board. Then look on the back and look at the solder joint. If you have a magnifying glass or good light - you'll probably see what I saw - a bad solder joint (cracked at the connector pin). Its neighbors may be bad also. Use a soldering iron and reflow with a little new solder. Do the others while you are in there. Put everything back together and enjoy beep-free driving.
Now I get to go rub it into the stealership - since they had no clue what the message even meant. I thought they would know how to fix it - yeah right. If you want it done, you gotta do it yourself.
phild328 is offline
post #2 of 141 Old 07-10-2005, 09:31 AM
bx cherokee
help !!!
will this cause a chain reaction of other sensors malfunctioning as well ??
bx cherokee is offline
post #3 of 141 Old 07-10-2005, 10:18 AM
greasefingers
greasefingers's Avatar
1994 ZJ
Excellent!! You do indeed learn so much more if there is no one else to turn to, except yourself. My ZJ does not have a VIC so I have no oil level or coolant level sensor. My oil pressure & fuel gauge did go bad, however. I now have fake paper gages glued to my dashboard instead
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 141 Old 10-09-2006, 12:19 PM
user jeep
this didnt work for me, you just got lucky!!
ZJ - 1995 Jeep Grand Cherokee
user jeep is offline
post #5 of 141 Old 10-17-2006, 11:00 AM Thread Starter
phild328
If all your connections are good, and your sensor is good, the only thing left is the VIC circuitry itself. You can trace the pcb and wire in a 3.3K resistor in the place of the coolent sensor. Verify the continuity of the traces or get as close to the IC as possible in case some of the other solder joints are bad. Re-flow many solder joints, it shouldn't hurt, should only help. Many electronic failures are due to the solder joint.
Try another VIC if all else fails (though do they have to be programmed to the car, I can't remember?) Only three things to it - the sensor, the wiring in between, and the VIC. Should be an easy fix. The huge thing was figuring out what was connected to what - which is in my first post.
If you didn't replace the sensor - do that first of course. Its like $10. Even if it tests good - it may be different in the car - with the coolent swashing around moving it around it could temporarily go open.
phild328 is offline
post #6 of 141 Old 10-23-2007, 07:59 PM
NO1WOLVERINE
Correction!
Well Phild328 you are right on many of your findings but I think you made a few typos! you are incorrect by saying that the sensor in the tank (float) shows 3.3 ohms when it is raised! It will be zero ohms because the contacts are closed. when the float is lowered (coolant low) it wil read the 3.3 ohms. Also when you unpug from the VIC and check that black and pink wire will again read zero ohms with the tank full. So you just had it reversed. But I congradulate you on helping me with my problem!! YES MINE IS NOW FIXED by following philb's instructions!! Thank you very much for this info!
NO1WOLVERINE is offline
post #7 of 141 Old 10-23-2007, 08:03 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
what the eff? OP has 5 posts and hasnt logged on in a year! well, good info i guess..
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #8 of 141 Old 10-23-2007, 09:18 PM
nashmd454
nashmd454's Avatar
o well...I don't wanna fix mine if I have to read a post that long....
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #9 of 141 Old 12-03-2007, 12:37 PM
bill-ns
Many thanks to the original poster... this fixed my coolant level sensor prob that I've been having for a couple years now. Found a couple broken solder points.
Bill
bill-ns is offline
post #10 of 141 Old 12-04-2007, 02:21 PM
ProductUser
Nicely done and thanks for posting the solution!
Tony
ProductUser is offline
post #11 of 141 Old 03-28-2008, 07:47 PM
00MaxSE
Wow I have a 96 Grand with the exact same problem! But I don't know if I want to tackle this fix since I'm selling it.
1996 ZJ 4.0L
***FS: '96 Grand Cherokee Laredo***
00MaxSE is offline
post #12 of 141 Old 03-28-2008, 07:51 PM
SpeedyCat3
Survivor
SpeedyCat3's Avatar
It is simple to do.
The most difficult part is to take the plastic bezel out first.
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
SpeedyCat3 is offline
post #13 of 141 Old 07-20-2008, 04:19 AM
belangers
correction again!
Mine is a 1998 Grand Cherokee, and the float reads 3.3k ohms with the float raised. The circuit opens when it is lowered, it doesnt close. The reading is infinity when float is down....... Another interesting fact is that this sensor is tied to the computer via the VIC, and does force the computer into closed loop, feeding it outrageous amounts of fuel, as it does during warm up. Fixing this increased fuel mileage exceptionally.
Phil was correct!, you must have a Polish float model....lol!
belangers is offline
post #14 of 141 Old 07-20-2008, 09:04 AM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
Guys the Coolant Level Sensor is in the coolant reservoir. Fix it for $20 and the message goes away. Worked for me.
Jeep Sold! 02/2009
Need AMSOIL?
LaCeS OuT is offline
post #15 of 141 Old 07-20-2008, 03:49 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
mine is going off now as well, so that is now on the list as well.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
"Coolant Sensor is bad" jhillstead ZJ Grand Cherokee Forum 4 07-02-2009 10:18 PM
96 GC. "Coolant Sensor Bad", Which sensor? seanf ZJ Grand Cherokee Forum 2 07-14-2007 04:16 PM
"Coolant Sensor Bad" seth586 ZJ Grand Cherokee Forum 5 06-21-2007 11:35 AM
"Coolant Sensor Bad"?? on '96 ZJ 5.2 oneillsean ZJ Grand Cherokee Forum 16 09-17-2006 12:14 PM
"Coolant sensor bad" Rock1127 ZJ Grand Cherokee Forum 1 10-01-2005 09:17 PM
