"Coolant Sensor Bad"?? on '96 ZJ 5.2 - JeepForum.com
post #1 of 17 Old 08-13-2006, 12:04 PM Thread Starter
oneillsean
The information center in the middle of the dash on my GC keeps flashing "coolant sensor bad." The engine temp is fine when I'm driving. Also, no problems with the coolant level in the reservoir - no leaks from the radiator or water pump, everything seems o.k.
The local Jeep service manager says there are three sensor but my Chilton's manual doesn't distinguish. I don't want to take it into the dealer if I don't have to.
Has anyone had a warning message like this before? '96 GC Laredo V8.
Thanks.
oneillsean is offline
post #2 of 17 Old 08-13-2006, 12:30 PM
van93zj
its the one in the reservoir i have a 1993 gc w\ the 5.2 and it did the same thing its 19.99 at oreillys just tell them coolant level sensor
van93zj is offline
post #3 of 17 Old 08-15-2006, 06:03 PM Thread Starter
oneillsean
Thanks for your help.
post #4 of 17 Old 08-15-2006, 06:07 PM
Wookie06
Mine has been lit for awhile. I always figured that's why it flashes coolant level low even when it is fine. I'll replace mine soon as well.
Wookie06 is offline
post #5 of 17 Old 08-15-2006, 06:20 PM
driabyor
driabyor's Avatar
1994 ZJ
it's called a buy new parts lights .. my 4 wheel drive switch and coolant sensor have been bad for about 6 years now...
oh I still havent replaced either one
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #6 of 17 Old 09-13-2006, 06:45 PM Thread Starter
oneillsean
I bought a new coolant sensor ($15) for the coolant reservoir and the ligtht still comes on. Checked the wiring connections and they seem o.k.
post #7 of 17 Old 09-14-2006, 11:17 AM
blakely03
It's a loose solder joint inside the VIC that is causing the circuit to open and close. You would have to take it apart and re-solder the joint...or just live with the flashing light. It is a very common problem with the ZJ. It won't hurt anything to let it flash like that...just make sure to manually keep an eye on your coolant level.
blakely03 is offline
post #8 of 17 Old 09-15-2006, 03:52 PM Thread Starter
oneillsean
Thanks alot. When you say the solder joint is in the VIC, you mean behind the center dash.
post #9 of 17 Old 09-15-2006, 04:08 PM
blakely03
Yes, the solder joint would be behind the screen. I have been meaning to pull mine out now for about 6 months...just haven't gotten around to it and have learned to live with the flashing.
post #10 of 17 Old 09-15-2006, 09:45 PM
user jeep
hey are you sure this will fix the problem? cuz if u are then im doing that tomorrow. thanks
user jeep is offline
post #11 of 17 Old 09-16-2006, 12:56 PM
user jeep
still looking to do this...
post #12 of 17 Old 09-16-2006, 10:13 PM
sgarlic
I know a lot of people have mentioned re-soldering the joint, but I wondered about whether or not that message refers ONLY to the coolant level sensor. Reason being, a few weeks back, I got that message, so I pulled out the coolant level sensor altogether, reconnected the harness, and got "coolant sensor bad" along with "low coolant." So it seems to me that the coolant LEVEL sensor was working just fine. Anybody looked at a wiring diagram from the sensors to the VIC to see if the coolant temp sensor runs through this circuit too?
96 5.2 Ltd - Flame Red - Every factory option except engine block heater,
, removed silencer, 15% tint.
sgarlic is offline
post #13 of 17 Old 09-16-2006, 10:32 PM
user jeep
where exactly is the joint. i took apart the dash and the screen and inspected the circut boards, re-soldered a few that looked imperfect, and im still getting the message...
ZJ - 1995 Jeep Grand Cherokee
post #14 of 17 Old 09-16-2006, 10:41 PM
phasewolf
You know what they say when in doubt shotgun them all. Sometimes a solder joint can be bad and look just fine and there are not a lot of them so just to be safe I would just add a little fresh solder to them all and call it a day. Cant hurt unless you bridge a joint so be careful not to do that.
phasewolf is offline
post #15 of 17 Old 09-16-2006, 10:44 PM
user jeep
oooo!... that'll take forever!
"Coolant Sensor Bad" FINALLY FIXED!!!! phild328 ZJ Grand Cherokee Forum 140 01-15-2017 01:39 AM
"Coolant Sensor is bad" jhillstead ZJ Grand Cherokee Forum 4 07-02-2009 10:18 PM
96 GC. "Coolant Sensor Bad", Which sensor? seanf ZJ Grand Cherokee Forum 2 07-14-2007 04:16 PM
"Coolant Sensor Bad" seth586 ZJ Grand Cherokee Forum 5 06-21-2007 11:35 AM
"Coolant sensor bad" Rock1127 ZJ Grand Cherokee Forum 1 10-01-2005 09:17 PM
