"Coolant Sensor is bad" - JeepForum.com
post #1 of 5 Old 07-02-2009, 04:16 PM Thread Starter
jhillstead
Okay, I get a message on the onboard computer that the "Coolant Sensor is Bad". I changed the coolant sensor located on top of the motor near the thermostat housing, still getting the code. Got any idea's?
jhillstead is offline
post #2 of 5 Old 07-02-2009, 04:42 PM
iluvtruenos
Put electrical tape over the EVIC?
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #3 of 5 Old 07-02-2009, 04:48 PM
coonash
coonash's Avatar
It's the sensor in your radiator overflow. Just cut the wires and stick them together.
Originally Posted by 5-90
This is an online forum, and the written word is the primary method of communication. If you make an effort to communicate clearly, people will be willing to communicate in return. If you don't make an effort, I don't see why I should - write like an idiot, and I'm going to think you're an idiot, that's just how things work.
USN Jeep Club Number 41
coonash is offline
post #4 of 5 Old 07-02-2009, 05:01 PM
StellaTheZJ
There's a thread or two on this, it's a common problem. If you changed your sensor and it's still a problem, you may have to repair your VIC.
http://www.jeepforum.com/forum/f13/coolant-sensor-bad-finally-fixed-175207/
I have the same problem, haven't dealt with it yet. Apparently though, simply connecting the wires together may not work, as the sensor should have 33k Ohms resistance in it. So, you could silence the offending alarm by putting a 33k Ohm resistor between the two wires.
http://www.jeepforum.com/forum/f13/coolant-sensor-bad-448277/
Good luck!
StellaTheZJ is offline
post #5 of 5 Old 07-02-2009, 10:18 PM
GrandHokie96
very common problem, check out this writup with PLENTY of pictures...
http://thespeedfreaks.net/showthread.php?t=1924
'98 Grand Cherokee 5.9L V8
-Stock suspension, 235/75R15 BFG AT's, AR767 rims with 4" BS - Fastman 52mm Throttle Body, K&N FIPK Gen 2, Kolak Exhaust, DMH Cutout, DT Headers, M1 Intake - 8300k 9004 Hi/Low HID's, 8000k H3 Off-Road Lamps - Rockford Fosgate P8002 and P4004 amps, 2x 12" Kicker CVR subs, Kicker SS56.2 components in Q-Logic kickpods, Front and rear Punch components, another set of components in the sound bar, 3600 watts total
GrandHokie96 is offline
"Coolant Sensor Bad" FINALLY FIXED!!!! phild328 ZJ Grand Cherokee Forum 140 01-15-2017 01:39 AM
96 GC. "Coolant Sensor Bad", Which sensor? seanf ZJ Grand Cherokee Forum 2 07-14-2007 04:16 PM
"Coolant Sensor Bad" seth586 ZJ Grand Cherokee Forum 5 06-21-2007 11:35 AM
"Coolant Sensor Bad"?? on '96 ZJ 5.2 oneillsean ZJ Grand Cherokee Forum 16 09-17-2006 12:14 PM
"Coolant sensor bad" Rock1127 ZJ Grand Cherokee Forum 1 10-01-2005 09:17 PM
