"Coolant Sensor Bad" - JeepForum.com
post #1 of 6 Old 06-19-2007, 06:31 PM Thread Starter
seth586
My center console says "cooland sensor bad", is this the thermostat or a different sensor? Thanks,
1996 ZJ 5.2L
4.5" RE Superflex
265x75x16 BFG ATs
Thule Roof Rack, K&N FIPK
seth586 is offline
post #2 of 6 Old 06-19-2007, 06:50 PM
SpeedyCat3
Survivor
SpeedyCat3's Avatar
Uhmmmmm...Let me see what a quick search brings up....
http://www.jeepforum.com/forum/searc...archid=1213006
Ok...
You'll see that the sensor the VIC takes the reading from is the level sensor inside the reservoir, not the engine one.
If you change it, flush the reservoir of all the crud that accumulates, and clean the connector.
If the message persists, but intermittent, the problem mor likely lies in a faulty VIC, which has been traced to be craked or broken solder points.
Try the easy fix first..
But before you do it, read some of the gazillion other posts, that might give more ideas on how to go about it....
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
SpeedyCat3 is offline
post #3 of 6 Old 06-19-2007, 06:58 PM
greasefingers
greasefingers's Avatar
1994 ZJ
The coolant temperature sensor (the one on the thermostat) is a very important sensor for fuel management and a code will be thrown if that one goes bad (which is not your issue)
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 6 Old 06-20-2007, 11:14 PM Thread Starter
seth586
I searched for "coolant sensor bad", but nothing came up. I did try, and thanks for the help =)
1996 ZJ 5.2L
4.5" RE Superflex
265x75x16 BFG ATs
seth586 is offline
post #5 of 6 Old 06-21-2007, 11:34 AM
SpeedyCat3
Survivor
SpeedyCat3's Avatar
Check the link I showed you.. there are at least 5 or 6 threads there.
And no prob... I have a weird sense of humor some times, but I was just kidding.
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
post #6 of 6 Old 06-21-2007, 11:35 AM
SpeedyCat3
Survivor
SpeedyCat3's Avatar
By the way, I have to do that same fix, cause I have that same problem right now, so I do it soon I'll post in this same thread.
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
"Coolant Sensor Bad" FINALLY FIXED!!!! phild328 ZJ Grand Cherokee Forum 140 01-15-2017 01:39 AM
"Coolant Sensor is bad" jhillstead ZJ Grand Cherokee Forum 4 07-02-2009 10:18 PM
96 GC. "Coolant Sensor Bad", Which sensor? seanf ZJ Grand Cherokee Forum 2 07-14-2007 04:16 PM
"Coolant Sensor Bad"?? on '96 ZJ 5.2 oneillsean ZJ Grand Cherokee Forum 16 09-17-2006 12:14 PM
"Coolant sensor bad" Rock1127 ZJ Grand Cherokee Forum 1 10-01-2005 09:17 PM
