coolant sensor bad?? - JeepForum.com
post #1 of 8 Old 02-08-2005, 08:40 PM Thread Starter
krawlin
The on board display on my 93 GC will flash coolant sensor bad every once in a while?? Where is the sensor so I can replace it? I is starting to drive me crazy.
krawlin is offline
post #2 of 8 Old 02-09-2005, 04:36 AM
Meerkat
If you look at your coolant recovery tank (on the passenger side fenderwell), you will see two "caps". One is for filling, the other has wires going to it. The one with wires is the coolant level sensor. You may not need to replace the sensor at all. You may just have a dirty or loose connection.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 8 Old 02-09-2005, 05:21 AM
marksto
Had the same "coolant sensor" problem on my '94 a few years ago. It was intermittant and drove me crazy for a long time. I removed the sensor and inspected it, cleaned it, etc.. to no avail. Save your sanity - go to the dealer and buy a replacement like I did.
marksto is offline
post #4 of 8 Old 02-09-2005, 06:21 AM
jeepholic
jeepholic's Avatar
Every time this topic comes up it's the same story, some say to inspect and clean the unit and others say to replace it period.
To inspect and clean the unit should take about 10 minutes, it may save you a trip to the store and a few bucks and give you a feeling of slight accomplishment, changing every part that you think is bad may work fine, but Jeeps are pretty durable and some items are cleanable in some cases, example:
I clean my IAC and the results are great
I clean my O2 sensor and the results are great
I buff the haze right off my headlights with great results
I clean the coolant sensor with great results.
I have also changed about 20 other bad parts on the truck including axles and pulleys, starters, alts, injectors and a ton of stuff that was unsaveable.
It doesn't hurt to try to clean it and check the connection before replacing it.
I use a Jeep
You drive a car
Big difference.
94 I6 ZJ at 4", 33's and front locker and 4.11 gears. Swampy Bypass.
Black Jeep Club Member Ver. 2 #51
jeepholic is offline
post #5 of 8 Old 02-09-2005, 08:13 AM Thread Starter
krawlin
Thanks for the help
krawlin is offline
post #6 of 8 Old 06-17-2011, 03:01 PM
Glued2aPost
Glued2aPost is offline
post #7 of 8 Old 06-17-2011, 06:08 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
The attack of the coolant sensor post,lol.
coralman is offline
post #8 of 8 Old 06-17-2011, 10:35 PM
Yekknom
1994 ZJ
lol this happened to me i replaced every damn sensor except that one and it turns out thats the only one that the jeep reads if its gone bad. and one of the coolant sensors was pretty much gone when i found it
Yekknom is offline
high voltage o2 sensor/bad coolant sensor Jh24k WK Grand Cherokee & XK Commander Forum 1 07-19-2013 10:22 AM
Coolant Sensor Bad MaroonGC ZJ Grand Cherokee Forum 21 05-22-2011 04:36 AM
coolant sensor bad??? cmckeon ZJ Grand Cherokee Forum 8 06-08-2007 01:19 PM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 03:52 PM
coolant sensor crazynut52 ZJ Grand Cherokee Forum 7 01-01-2005 03:08 PM
