Coolant sensor - JeepForum.com
post #1 of 4 Old 04-02-2011, 08:06 PM Thread Starter
shawn_in_pdx
Coolant sensor
My interior "message center" always shows my coolant sensor is bad...but that sensor has been replaced...still goes off... Suggestions??
shawn_in_pdx is offline
post #2 of 4 Old 04-02-2011, 08:14 PM
MegaAlan
1990 XJ Cherokee
Code needs to be cleared.
90 XJ (Under Construction) Elec fan switch to dash. Overheating issue solved!
06 Dodge Megacab Cummins Diesel: 37X13.5 Mickey MTZ's/ 6" Superlift/ 6" dia. chrome miter smoke stacks.
MegaAlan is offline
post #3 of 4 Old 04-02-2011, 08:15 PM
MegaAlan
1990 XJ Cherokee
Takes a scan tool.
MegaAlan is offline
post #4 of 4 Old 04-02-2011, 09:30 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Are you talking about the vehicle info center below the radio? Vics have been known to have a bad solder joint that causes that message to display. Search "bad coolant sensor finally fixed". There is a write up that shows you how to resolder the connections eliminating the message.
coralman is offline
coolant , sensor
high voltage o2 sensor/bad coolant sensor Jh24k WK Grand Cherokee & XK Commander Forum 1 07-19-2013 10:22 AM
Coolant Sensor Bad Wesley5 ZJ Grand Cherokee Forum 2 07-19-2007 06:53 PM
Coolant sensor bad Frostbite ZJ Grand Cherokee Forum 1 06-09-2007 01:51 PM
bad coolant sensor cblake ZJ Grand Cherokee Forum 2 01-24-2007 03:48 PM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 03:52 PM
