Coolant podle, thermostat or pump? - JeepForum.com
post #1 of 5 Old 08-16-2009, 06:55 PM Thread Starter
porrsher
1994 ZJ
I Okay so I replaced the upper hose this weekend, now I noticed that the zj is leaking after it's parked and reaches normal O Temperture. I tracked it down to near the pump but can not really tell whether it is comming from the thermostat housing or the top of the water pump. I can see coolant puddling near the housing. Could this be the top of the pump or the housing?? This picture is looking from top of engine down from where the upper hose inlet, behind the alternator. So not sure if it is comming from the back of the seal of the water pump of the thermostat housing.
1994 Hunter Green ZJ 5.2L Quadratrac
228k Miles, 2" BB.
2002 Slate Grey Grand Cherokee Overland
161k Bone Stock
2008 Black JK Sahara Unlimited (Love it!)
porrsher is offline
post #2 of 5 Old 08-16-2009, 07:28 PM
tennesseewj
The water pump will have a weep hole in the bottom of it. If there is fluid coming out of that weep hole - the pump is on it's way out. If that weep hole is dry, it could be the thermostat.
2004 4.0 Selec-Trac
BB->Black Diamonds->General Grabbers
Originally Posted by Sporer65 View Post
You need to learn, there are 3 things that all JF members must like beside Jeeps:
(1) Guns (2) Women (3) Bacon
Originally Posted by GraKee99 View Post
I was bored so I forded the river. No oxen were lost.
tennesseewj is offline
post #3 of 5 Old 08-16-2009, 08:20 PM
elmer_fud
also check the bypass hose
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #4 of 5 Old 08-17-2009, 02:47 AM
Colorado 5.9
Colorado 5.9's Avatar
Double check the hose clamp. That type will loosen after a bit when first tightened. Hell, they loosen at anytime. I hate those clamps. I'm going to all T-Bolt clamps soon when I do the SC.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #5 of 5 Old 08-17-2009, 04:49 AM
Turbonut
A pressure tester is ideal to check for leaks as it can be used on a cold engine. Pump it up and let it sit, you'll find the leak.
Sprinkle some talcum powder around the area as then you'll be able to see if it's coming from the stat housing or leaking from the hose.
Also, as stated above, that bypass hose has a tendency to be forgotten, so it deteriorates and leaks.
Turbonut is offline
New Water Pump/Thermostat, now no heat tfgnt16 ZJ Grand Cherokee Forum 19 12-11-2009 08:49 PM
Is this a thermostat, fan , fan relay or water pump problem? tomtomtom ZJ Grand Cherokee Forum 14 02-10-2009 05:47 AM
Coolant Temp & Thermostat OK? 1995 GC 4.0L sarnone ZJ Grand Cherokee Forum 11 01-15-2009 07:50 PM
ZJ Heating problem! Checked thermostat, and coolant level... EngineerJoe ZJ Grand Cherokee Forum 12 11-29-2008 10:18 AM
Bad Water Pump or Thermostat? dpierson ZJ Grand Cherokee Forum 19 12-23-2004 10:41 PM
