coolant low...but its not low - JeepForum.com
post #1 of 9 Old 01-16-2010, 09:46 PM Thread Starter
RanTJWJ
I just bought a 2002 wj reading low coolant on the ceiling center council. Anyone had this and is it just a a "gooped up" sensor or do i need to replace it.
RanTJWJ is offline
post #2 of 9 Old 01-16-2010, 09:48 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Had the same problem on a 99. Replaced the sensor and its been fine. Was only about $10 at the dealer.
I Have WJ Stuff for Sale
WiCkeDuDe is online now
post #3 of 9 Old 01-16-2010, 09:51 PM Thread Starter
RanTJWJ
what do i have to do?
RanTJWJ is offline
post #4 of 9 Old 01-16-2010, 10:05 PM
Howiedooit
I think the sensor is in the reservour, they read low when there is no fluid between the contacts of the sensor, so a gooped up sensor is less likely then a loose wire at the sensor, or a loose plug to the sensor. make sure the tank is full, then check the system behind the sensor by connecting the two wires by what ever means you want.. paper clip.. jump wire.. the light should go out narrowing it down to the sensor, check the sensor with a continuity testor, continuity when full, no continuity when empty. good luck
Howiedooit is offline
post #5 of 9 Old 01-16-2010, 10:14 PM
ZJJay
ZJJay's Avatar
There was a thread a while back about this same problem. After testing the sender and the wiring, a member deterined the problem was with a bad solder connection on the back of the Vehicle Information Center (a display in the lower center console of a ZJ).
I was having this same problem. My sender tested good, but I decided to replace it anyway. After that I've had the warning message and chimes only once. It hasn't reoccurred in the past four months. I'll wait until it becomes a problem again before I remove the VIC and resolder the connections.
'96 ZJ, 4.0L, 42RE, NP242, stock D30 and D35-LS w/ 3.73, 4-1/2" lift, 32" BFG ATs, Magnaflow, JKS track bars and disconnects, spare tire carrier, Optima red top, ROLA roof rack, KC SlimLite driving lights, CB and Yaesu ham radios, GPS
ZJJay is offline
post #6 of 9 Old 01-16-2010, 10:17 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #7 of 9 Old 01-16-2010, 10:35 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #8 of 9 Old 01-16-2010, 10:57 PM Thread Starter
RanTJWJ
thanks everyone for the help. jf coming through yet again.
RanTJWJ is offline
post #9 of 9 Old 01-16-2010, 11:21 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Sig worthy!
Max
Mean Max is offline
What coolant should I use? brsox88 ZJ Grand Cherokee Forum 11 03-03-2008 04:48 AM
What coolant should I use? brsox88 ZJ Grand Cherokee Forum 1 03-02-2008 05:38 PM
Air in coolant stroker60 ZJ Grand Cherokee Forum 5 02-23-2008 11:05 AM
Low Coolant rflem550 ZJ Grand Cherokee Forum 9 02-14-2008 09:11 AM
coolant...? Reloader77724 ZJ Grand Cherokee Forum 4 12-18-2006 07:32 PM
