Coolant level sensor bad - is this serious? - JeepForum.com
post #1 of 11 Old 11-04-2004, 11:10 AM Thread Starter
Gracie
Hello -
My 96 Grand Cherokee Limited has started telling me that my coolant level sensor is bad. I have a leak somewhere in my cooling system and so every month or so I usually have to add antifreeze.
For some reason, I haven't had to add antifreeze for awhile. So I'm wondering - does "coolant level sensor bad" mean:
a) that the sensor in the reservoir just isn't going to let me know when I need to add more antifreeze and so I need to pay close attention to the antifreeze level or
b) does it mean that the sensor isn't going to let any more antifreeze into the system from the reservoir (which seems more serious)?
Thanks for all your help!!
Gracie is offline
post #2 of 11 Old 11-04-2004, 01:58 PM
greasefingers
greasefingers's Avatar
1994 ZJ
I don’t have your type of system but I would assume that the message is displayed in a cryptic way. In other words “Coolant level sensor bad” probably means that the coolant level in the reservoir is low. Coolant is always allowed to flow back & forth between the reservoir and radiator when needed.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 11 Old 11-04-2004, 02:53 PM Thread Starter
Gracie
Originally Posted by greasefingers
“Coolant level sensor bad” probably means that the coolant level in the reservoir is low. .
That was the first thing I thought of, too. But when I checked the reservoir it was completely full.
When my reservoir is low, the car says "Coolant level low". That's why when it says "coolant level sensorlbad" I knew that was something different.
Does that clarify it any?
Thanks!
Gracie is offline
post #4 of 11 Old 11-04-2004, 03:04 PM
greasefingers
1994 ZJ
I guess the computer knows the sensor is bad when it receives a signal that is out-of-range. Maybe someone with you’re your type of system can reply?
Cheers Steve
post #5 of 11 Old 11-04-2004, 08:31 PM
ZJGuido
Junior Member
ZJGuido's Avatar
No it's not a serious issue. "Coolant Level Sensor Bad" simply means that the sensor that measures the amount of coolant in the resevoir is not functioning properly and needs to be replaced. It has no affect whatsoever on the operation of your cooling system. If you suspect that your cooling system is leaking coolant, then you'll have to keep an eye on level because the sensor is no longer measuring the actual level properly. If you want to replace the sensor, it's located right on top of the coolant resevoir and can be simply removed by pulling it out from the top.
1998 Platinum ZJ 5.9 Limited
K&N FIPK / MOPAR ECU / Bilstein Shocks / H&R springs / Addco sway bars
ZJGuido is offline
post #6 of 11 Old 11-05-2004, 08:29 PM Thread Starter
Gracie
Hey Guido - thanks so much! That's my maiden name - maybe we're related!
Greasefingers - thanks for your help as well.
What did we ever do without the internet? Such a wealth of information from so many great people!
Thanks!!
Gracie is offline
post #7 of 11 Old 11-07-2004, 09:27 AM
djvan
Try a radiator cap for the leak, this is a cheap thing to check.
DougV>
djvan is offline
post #8 of 11 Old 11-17-2004, 10:02 PM
jotho
Gracie - Did you find the problem? Maybe just cleaning the sensor will help...I'd imagine it can get pretty gummed up after 6 years.
jotho is offline
post #9 of 11 Old 11-18-2004, 02:48 PM
kentman
kentman's Avatar
2006 XK Commander
DougV>
How many miles of operation before a cap would typically go bad?
I have a very slow leak right up front, and I believe it to be the radiator, but I guess that it could be the cap. I will try that first, but I am not optimistic that it will solve my issue.
I have 172K. Thus, it could easily be the radiator itself.
Kent
kentman is offline
post #10 of 11 Old 11-18-2004, 03:17 PM
GPERSCREEPERS99
GPERSCREEPERS99's Avatar
My sensor just deteriated(SP) said the same thing. The plastic cracked and mine is like a float it took on coolant and it always said I was low I zip tied it up and now just check once a month. Not a serious problem. If it wasn't allowing antifreeze in you would be overheating. Not worth the money to fix. I forget how much it was but not worth it.
99 Jeep Wrangler built on 35's
82 Aqualu Aluminum Scrambler Chevy 350 on 33's
14 JKU Rubicon My Daily Driver
12 Grand Cherokee Wife's Daily Driver
GPERSCREEPERS99 is offline
post #11 of 11 Old 11-18-2004, 08:19 PM
dadjlh
Not worth it? Part number is : S8108 O'Reilly auto parts, cost $12.38.
1994 Grand Cherokee Limited (Silver)
4.0 I6 42RE
NP242
Dana30/Dana 35C 3:73
1988 Comanche Pioneer (Blue)
4.0 I6 AW-4 2WD
D35C Rear Axle
dadjlh is offline
4.0L Coolant level tfgnt16 ZJ Grand Cherokee Forum 2 12-22-2008 08:15 PM
2001 GC low coolant level light Steve in PA ZJ Grand Cherokee Forum 2 10-18-2008 12:30 PM
Low coolant level kopite77 ZJ Grand Cherokee Forum 14 02-12-2007 10:53 AM
Coolant Level Low??? Jay Arno ZJ Grand Cherokee Forum 4 01-26-2005 08:08 PM
low coolant level alarm msafrit ZJ Grand Cherokee Forum 3 01-23-2003 08:52 PM
