Coolant Leak From Front of Engine - JeepForum.com
post #1 of 8 Old 02-26-2010, 03:42 PM Thread Starter
jeep360limited
i was coming out of NAPA today, the jeep needs more money spent on it, and i noticed there was a puddle of coolant underneath. i got under it and it looked to be dripping off the harmonic balencer. i dont think it would be leaking from there, maybe a hose higher up or from the water pump is what i was thinking.
any help would be appreciated.
Thanks
Charlie
2003 Ford Ranger Edge
1986 Jeep CJ7
1998 Jeep Grand Cherokee 5.9 Limited-----SOLD
jeep360limited is offline
post #2 of 8 Old 02-26-2010, 04:12 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
Thanks
It could be coming from anywhere in the area, but I would bet money that your water pump shaft seal is leaking.
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #3 of 8 Old 02-26-2010, 04:21 PM
92rslt1
water pump
02 overland, bone stock
92rslt1 is offline
post #4 of 8 Old 02-26-2010, 04:25 PM Thread Starter
jeep360limited
would i need to replace the water pump, and if so, is it that hard to do by yourself?
Charlie
1986 Jeep CJ7
post #5 of 8 Old 02-26-2010, 04:31 PM
SlimGoaty
SlimGoaty's Avatar
1997 XJ Cherokee
start looking into the water pump, it could also be coming from the timing cover. There are small water-ways that flow between the water pump, timing cover, and block. This is not really a fun job at all but if you let it go and it leaks into the timing cover it will start mixing with the oil. I think I was quoted at 900$ to have it done and thats at only 60$ an hour labor. More than likely your water pump like mentioned.
97 XJ 4.0, AW4, 231, RE 5.5, Tom Woods DS, AA SYE, 35x12.50 KM2,
Upgraded Harness, PIAA bulbs, Rustys Tie-Rod, L&L Fab bumper,
Quadratec 9500i Winch, Aussie locker, 4.88's
SlimGoaty is offline
post #6 of 8 Old 02-26-2010, 04:41 PM
SJZ
SJZ's Avatar
Yes, you would need to replace the water pump. Hard or not is subjective. Folks do it every day on similar vehicles, right in their driveway. If anything, it should be a little easier for you with the 5.9, since you don't have the mechanical fan & it's associated shroud to remove.
Get a mirror & a flashlight, and see if you can verify that coolant is coming out the weep hole, aft of where the shaft exits the water pump casting. Check when the system is under pressure. You would hate to change the pump unnecessarily.
-Steve
SJZ is offline
post #7 of 8 Old 02-26-2010, 05:02 PM
Mazdarx
I just changed mine, it was pretty simple. I think it took me maybe 3 hours all together and I was taking my time. You will need a few tools to do it, you need a socket and an extension, and a combination wrench. I forget the exact size, but it might be 9/16. Anyway it is much easier as mentioned on a 5.9 than a 5.2 as the electric fan makes it much easier. That clutch fan is a pain, when my dad did his he made a tool out of flat steel to get that off. The belt is easy, just put a wrench on the tensioner and pull it to the drivers side, it will release the tension from the belt and then you can slip it off while you hold the tensioner to the side. Water pumps go quite often on these, mine is on its 3rd now that I know about. As is my dads 96, and its almost due for another we figure.
-My business, being self-employed rocks.
91 Yj Renegade, lifted, built 4.0L, 33's etc
Mazdarx is offline
post #8 of 8 Old 02-26-2010, 05:36 PM Thread Starter
jeep360limited
ok i will see what i can do, thanks guys
Charlie
1986 Jeep CJ7
Coolant leak on front of 5.2L...frost plug? Coletrickle ZJ Grand Cherokee Forum 10 01-18-2010 05:59 PM
coolant leak JD37055 ZJ Grand Cherokee Forum 5 11-29-2009 05:18 PM
Coolant leak Travis873o ZJ Grand Cherokee Forum 2 09-24-2009 01:38 PM
Coolant Leak 97GrandCherokee ZJ Grand Cherokee Forum 4 02-17-2007 05:30 AM
Coolant leak and engine not starting natedawg WJ Grand Cherokee Forum 7 03-11-2004 02:38 PM
