Coolant leak - JeepForum.com
post #1 of 3 Old 09-24-2009, 01:21 PM Thread Starter
Travis873o
Coolant leak
I'm leaking coolant. The belt squeaks bc of the coolant leaking on it. I think it's from the water pump, not sure. Any suggestions? Also if it is from the water pump, what would I have to replace? Just the gasket or the whole pump?
Travis873o is offline
post #2 of 3 Old 09-24-2009, 01:34 PM
the88thpianoman
2003 WJ
Take a look under there and observe where it's leaking from. If it is leaking from the water pump, it is unlikely to be the gasket, and probably is coming from the weep hole. Either way, it's something that needs to be physically observed.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #3 of 3 Old 09-24-2009, 01:38 PM Thread Starter
Travis873o
Didn't know there was a weep hole. If it is coming from there then what? Also what is the weep holes purpose? Why would a water pump need one?
Coolant Leak? WyomingJeep89 ZJ Grand Cherokee Forum 1 07-09-2009 01:11 PM
Coolant Leak? drob951 ZJ Grand Cherokee Forum 22 06-21-2009 10:07 AM
Coolant Leak Killer Cougar ZJ Grand Cherokee Forum 3 11-04-2007 11:17 AM
Coolant Leak djdoug99 ZJ Grand Cherokee Forum 26 06-14-2007 09:30 PM
Coolant Leak 97GrandCherokee ZJ Grand Cherokee Forum 4 02-17-2007 05:30 AM
