coolant fan not powering on with ac - JeepForum.com
post #1 of 9 Old 08-19-2006, 10:45 PM Thread Starter
jeremypittman
Just picked up a 98 GC limited with the 5.9 ltr.... The radiator fan doesnt come on with the ac being powered on... The radiator fan does work just fine with the heat of the coolant turning it on and off. since the fan doesnt power on with the ac, I dont have any cold air when I'm setting still.
Any ideas? Relay maybe?
thnx
jeremypittman is offline
post #2 of 9 Old 08-19-2006, 11:18 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
thnx
http://www.netpreview.com/98zjcooling.pdf
What you're looking for starts on page 8.
Here's the wiring diagram:
http://www.netpreview.com/98zjwiring.pdf
Sheet: 8W-30-31
Looks like the low speed fan comes on with the AC. When you say it works fine with cooant temperature, I wonder if you are seeing high speed only? Maybe your low speed relay or motor winding is NG. Sould be easy enough to troubleshoot, now that you know how it works (after reading PDF).
-Steve
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #3 of 9 Old 08-19-2006, 11:22 PM Thread Starter
jeremypittman
that would make sence... I'll start with the low speed relay...
Thanks, If you think of anything else just drop me an email....
post #4 of 9 Old 08-19-2006, 11:43 PM
SJZ
SJZ's Avatar
Check your PM.
-Steve
SJZ is offline
post #5 of 9 Old 08-20-2006, 10:27 AM Thread Starter
jeremypittman
Well I took the high speed relay and plugged it into the low speed connector and did the same with the low speed relay into the high speed connector. The fan still didnt power on with the ac... I am going to let it idle and see if it powers on with the coolant temp. If it does, and I'm thinking correct this would indicate that both relays are good.
How would one trouble shoot the low speed winding in the fan motor?
Only way I can think of is to check with an ohm meter..
Jp
Sheet: 8W-30-31
-Steve
post #6 of 9 Old 08-20-2006, 01:14 PM Thread Starter
jeremypittman
Found the low speed winding in the motor to be at fault. Relays are putting power to the motor when they should but fan doesnt move. Checked to ohms on the high speed winding and got "0" checked on the low speed and it read open....
Now on my way to get a new fan motor... Thanks for all the help
Jp
post #7 of 9 Old 08-20-2006, 01:31 PM
SJZ
SJZ's Avatar
Better make sure that is not merely a poor connection (i.e. motor wire to conector) before buying a motor.
-Steve
-Steve
SJZ is offline
post #8 of 9 Old 08-21-2006, 06:48 PM Thread Starter
jeremypittman
Well checked the price on the new fan motor ouch $300+ complete asy. For right now I'm going to re-wire it so that when the low relay powers it will run the fan in the hi speed.
post #9 of 9 Old 08-21-2006, 07:28 PM
SJZ
SJZ's Avatar
You have a PM
-Steve
SJZ is offline
Powering another amp off of infinity amp? whatpavment? ZJ Grand Cherokee Forum 16 01-31-2008 09:41 PM
5.9L powering off randomly dundun ZJ Grand Cherokee Forum 7 12-16-2007 04:14 PM
Low Coolant KingPrat ZJ Grand Cherokee Forum 1 02-08-2007 04:07 AM
Low Coolant thejeeper02 ZJ Grand Cherokee Forum 4 01-09-2007 04:01 PM
How much coolant do you use? canuckJGC ZJ Grand Cherokee Forum 11 11-21-2005 10:22 AM
