Quantcast Cooking bacon in my rear dif? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Cooking bacon in my rear dif?
Old 02-06-2006, 03:46 PM   #1
patriot2005
It's been about a week since I drove my GC (I've been driving my wrangler instead). Last night I ran the GC up to the gas station to fill up and when I got back home, shut off the engine I heard a very noticeable sizzling and crackling sound coming from the rear. Crawled underneath and it sounded like there's bacon frying in my rear dif... sort of crackling and popping like oil in a frying pan.
Dif fluids were changed about 3 months ago and I haven't heard any such noises before last night and no visual fluid leak on the garage floor or around the dif.
Any suggestions on what this could be? It's definitely not your ordinary cooling down noise (like the radiator makes sometimes).
'01 TJ Sport, 4.0L, Auto, Silver, RE BB, 31x10.5" BFG AT's... and some other stuff.
'01 Jeep GC Limited, 4WD, V8, Auto, Silver
patriot2005 is offline   Reply With Quote
Old 02-06-2006, 03:51 PM   #2
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
pop off the fill hole cover (after it has cooled) and make sure you have enough fluid in there and see if it is burned. Drive it through water recently? Possibly water in the diff?
ArloGuthroJeep is offline   Reply With Quote
Old 02-06-2006, 03:52 PM   #3
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Are you sure it was the diff? Water + hot rotors = sizzle sizzle.
HTH
-Tim GS-MW 2009 INFO
KD8EBC
'94 ZJ 5.2 LTD
Project TORTOISE Build-up thread
JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick
EMTimZJ is offline   Reply With Quote
Old 02-06-2006, 03:55 PM   #4
Varkyl
No where near stock
Varkyl's Avatar
Was there alot of heat emanating from the diff housing? If it causing that kind of response in the oil then the housing my be discolored as well. If this is the case then there is a bearing that is toast!
Varkyl is offline   Reply With Quote
Old 02-06-2006, 03:57 PM   #5
patriot2005
Would have checked the level this am but didn't have time. So I just drove the wrangler in to work. Plan to check it this evening. I didn't run in any water, but it was cold out a few nights this weak if temp may have anything to do with it - since it's been sitting all week.
I don't change my own dif fluid becuase it's not that expensive to have done and the one time I did it I made a god awful mess. But I suspect that may be the problem. But that was 3 months ago, so I'm not sure. Thx
Old 02-06-2006, 05:29 PM   #6
BlaineWasHere
Addicted to Boost.
BlaineWasHere's Avatar
I would also make sure it have the correct fluid. If you have a vari-loc or trac-loc it takes a spacific fliud recipe.
2007 VW GTI
BlaineWasHere is offline   Reply With Quote
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
