Converting all dash lights to blue... - Page 2 - JeepForum.com
post #16 of 37 Old 01-07-2009, 06:25 PM
squashman702
1994 ZJ
Can someone provide a little more detailed writeup for us dummies out there?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #17 of 37 Old 01-07-2009, 06:42 PM
Jakeb2k4
Please Do A Write Up With Picssss Pleazzz
1995 Jeep Grand Cherokee Limited 5.2 V8
2.25" Budget Boost
31" BFG All Terains
Jakeb2k4 is offline
post #18 of 37 Old 01-07-2009, 06:47 PM Thread Starter
aaron7
Pics of the progress so far...
89 MR2 MK1.5
74 CB360
83 Firebird
79 Dodge Shasta 22' RV
aaron7 is offline
post #19 of 37 Old 01-07-2009, 06:55 PM
BLACKzj52
thats lookin real good.
can you possibly do a write up??
with a parts list of how many of what bulb?
i could tell you guys all day about the rest of the bulbs but idk about the small ones that go on the circuit boards.. not yet atleast
BLACKzj52 is offline
post #20 of 37 Old 01-07-2009, 07:29 PM
vredenburg08
Some pictures in here and details as well. scroll down to find them.
http://www.jeepforum.com/forum/f59/show-us-your-instrument-panel-pics-639864/
2000 Jeep Grand Cherokee
3" Iro
265/70 16 BFG ATs on JK wheels
Originally Posted by yjislander
used to have one that walked on mine .22 took care of that
vredenburg08 is offline
post #21 of 37 Old 01-07-2009, 07:52 PM
BLACKzj52
http://www.jeepforum.com/forum/showthread.php?t=639864
been there done that.
he has done the HVAC controls however, whereas i havnt learned which bulbs you need, how many of each, and where to solder. plus im terrible at soldering.. so im waiting to hear back and see some pic of how he did them.
post #22 of 37 Old 01-07-2009, 11:36 PM Thread Starter
aaron7
I don't have pics of the HVAC, but all I did was solder in LED's with 470ohm resistors and tie them all into the + and - of the dash lights. I have to redo it with a red LED for the hot side of the thermostat as you can see in the pics... it doesn't light up with the blue LED haha
I still have to pull the headlight and rear wiper switches to do those though.
89 MR2 MK1.5
74 CB360
83 Firebird
aaron7 is offline
post #23 of 37 Old 01-08-2009, 12:28 AM
dcvance87
I just ordered more 10mm neo-wedge blue LED's for my heater knobs and headlight switch. I'll ad my pics to this collage when I'm done....that is...when my bulbs get here
06' TJ, 4" Rough Country lift, 2" body lift, 35 BFG all-terrains.
dcvance87 is offline
post #24 of 37 Old 01-08-2009, 08:05 AM
BLACKzj52
aaron, how many bulbs did you use for the HVAC? and waht size? 8mm?
post #25 of 37 Old 01-08-2009, 08:25 AM
wsar10
2003 WJ
depending on the color and size of the L.E.D's they should only require a few Milli. amps of power, your resistors should be kinda higher in wattage (due to heat disipation), I think some of you that are using just any resistor or none at all have electronical problems in your futre, and heat disipation problems which is going to cuase major issues inside your dash. I would start doing a little math and learn a little about ohm's law before messing with L.E.D.s but it sounds like some of you hav.
wsar10 is offline
post #26 of 37 Old 01-08-2009, 11:09 AM
BLACKzj52
use these equations to calculate the right numbers
P=VI
and/or
V=IR
where:
P = Power (watts)
V = Volts (Volts)
I = Current (amps)
R = Resistance (ohms)
post #27 of 37 Old 01-08-2009, 12:08 PM
Chris93zj
is this a dual/jensen i/d i see? lol!
I really like the pics of what you've done...considered it myself..but not sure I like how bright some of the dash lights are. How good are they with the dimmer?
Chris93zj is offline
post #28 of 37 Old 01-08-2009, 01:35 PM Thread Starter
aaron7
Dual? Jensen? EW no. This is a Valor. Read the reviews... 5 stars on Crutchfield. Specs are great, price is great, win.
The dimmer does little. Dims a little then shuts off.
89 MR2 MK1.5
74 CB360
83 Firebird
aaron7 is offline
post #29 of 37 Old 01-11-2009, 07:46 PM
Chris93zj
valor...dual..jensen... same difference... To each his own there...
I figured they wouldn't dim much if/at all using the dimmer...LED's..that was kinda a dumb question lol.
Got another question for ya...did you actually get the flip to open up all the way, or does it hit your dash? cuz if it does, I got a fix Only about 20 bucks and a bit of epoxy..super easy
I do like the idea...now I gotta figure a way to change color without losing my dimmer...I'm sure I'll figure something out lol. Thanks again for the ideas.
post #30 of 37 Old 01-11-2009, 08:03 PM
compcrasher86
my dream dash, right there! damm I want that headunit too
HOW?!?!? cause I want to buy the jensen vm9512 and it looks like its going to hit the overhang over the radio in the dash
Originally Posted by BLACKzj52 View Post
I see you added LEDs to the door lights, I want to do that, and have 100 white LEDs and matched resistors so where did you get your 12v source from and how did you go about mounting the LED's. It looks like there was meant to be a light there anyways, they even put in clear plastic so I dont know why Jeep didnt put lights in there in the first place
Matt
compcrasher86 is offline
no parking lights, rear wiper, dash lights flash with blinker kemicalburns ZJ Grand Cherokee Forum 6 04-23-2010 08:45 PM
Blue Dash Lights dmolaver15 ZJ Grand Cherokee Forum 6 01-19-2009 09:33 PM
converting to stock fog lights? tbick ZJ Grand Cherokee Forum 7 10-07-2008 10:07 AM
converting my wood dash to the aluminum 99wjman ZJ Grand Cherokee Forum 21 05-17-2006 10:21 AM
95 GC Lt-Blue Beneath Dash -Joe- ZJ Grand Cherokee Forum 7 02-16-2005 11:34 PM
