Control arm question - JeepForum.com
post #1 of 3 Old 08-26-2013, 08:31 PM Thread Starter
Pugulis
So I've been tracking down a DW problem and have gotten to changing the front lower control arm bushings (they are toast). The question I have is does it matter which direction the bushings are facing? I actually bought the entire control arms with bushings already in place and they are both identical. And it appears that the front bushing is the one with the hollow spots. The problem is that if I install the passenger side, as it is, the bushing will be installed in the opposite direction from the original. I don't think it matters, but I just wanted to make sure. Thanks ahead of time.
[_][]☺[][][]☺[][_] 96' Grand Cherokee Laredo 265,000 miles and still going strong.
Pugulis is offline
post #2 of 3 Old 08-26-2013, 08:39 PM
newfieZJ
Stock are the same also . Mine have the flange side towards the driver's side on both sides . Arms are identical and the bushings only go in the arm one way . Shouldn't matter which way they get installed provided the proper bushing is on the axle side since yours appear to have the factory style bushing
newfieZJ is offline
post #3 of 3 Old 08-26-2013, 08:47 PM Thread Starter
Pugulis
That's the weird thing. The original one on the passenger side had the flange pointing in the opposite direction. But i figured it was more important to have the proper bushing up front.
Pugulis is offline
