Control arm cam bolts - JeepForum.com
post #1 of 16 Old 12-07-2011, 12:52 PM Thread Starter
black97grand
Was putting polyurethane bushings in my control arms last weekend and when i got to one of the cam bolts it turns out it is siezed to the inside of the bushing. It will not come out. I priced one out because im going to have to cut it off and it is $38! Can i just use a regular bolt or do i have to have that special one?
black97grand is offline
post #2 of 16 Old 12-07-2011, 01:05 PM
sebian
That bolt has a machined surface to match the flat surface on the cam washer. If you felt so inclined, you might be able to get away with a grade 8 bolt, and grind/machine one side to make is work with the cam washer. If it makes you feel any better, I had to pony up the benjamins for all 4 sets of bolts on the front. But the Jeep parts guy did toss in a free Jeep hat, think he felt bad for making me pay $130 for a set of 4 bolts.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #3 of 16 Old 12-07-2011, 02:07 PM Thread Starter
black97grand
What is the point of those cams? Just to lock the nut? Or does it position it or something?
post #4 of 16 Old 12-07-2011, 02:12 PM
speedbucket
I've never had cam bolts
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #5 of 16 Old 12-07-2011, 02:17 PM
1slo_camaro
HUGE difference, i did a F>R swap with springs, and put Extended LCAs, lost my cam washers and new from jeep you can get 2 bolts, nuts and washers..... break well over 100 bucks, ill find a link a company makes a kit for it and its only like 30 bucks for 2 lower bolts, nuts, and washers. i took some 3/16 steel cut it in a square to fit in the little valley, and drilled the hole tight for a grade 8 bolt to fit all the way backwards... ill post a pic and the link when i get it all
Heres the bolt kits.
http://shopping.yahoo.com/782072437-...nXkSv2YqoYGhoF
Here is another one
http://zoneoffroad.com/product-acc?ki=154&gr=2
heres how i did mine. i still need to grind them down paint them and all but i had to get it all in there and get the death wobble fixed, and it fixed it
1998 ZJ~~V.r 4~~4.0 with a bunch of fancy stuff that makes it look pretty sitting in the driveway.
PM me for 99+ intake manifolds for sale
$125-sandblasted and painted and shipped
1slo_camaro is offline
post #6 of 16 Old 12-07-2011, 06:57 PM
Devanzj
I had to replace mine when i snapped 2 installing my lift, I got them for 5.00 at the jy and they looked brand spankin new ....its worth a shot
97 ZJ 5.2L, NP231, 6"ish lift, 33" KM2s, hp30, IRO front long arms, Clayton rear long arms, JKS quick discos, BDS Shocks, Flowmaster Super 10 Series muffler, KOR style bumper
Build Thread -
On the way/waiting to go on: ford 8.8, 4.88s
Devanzj is offline
post #7 of 16 Old 12-08-2011, 07:21 AM
KJK
They set the caster angle of the front axle. It's important for steering and pinion angle.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #8 of 16 Old 12-08-2011, 07:35 AM
KoreaZJ
1994 ZJ
Soaked mine with Liquid Wrench for a couple of weeks first, came right off.
KoreaZJ is offline
post #9 of 16 Old 12-08-2011, 07:43 AM
merlot2twisty
RockAuto has a set of 2 bolts with washers, etc for $30.
ACDELCO Part # 45K0181
merlot2twisty is offline
post #10 of 16 Old 12-08-2011, 02:50 PM
mr4x4
I think I have some spares in my tool box I find them at the junk yard no charge
94 stock zj and a 95 zj with a 5.5" lift with 35" bfg km2 a rear currie 9in with 4.56 gears an arb and 35spine axle shafts and 4.56 gears in the front Hp30 super30 kit arb 4.1 low range transfercase
mr4x4 is offline
post #11 of 16 Old 05-12-2014, 09:38 PM
iann32
does anyone know if any parts store carry an equivalent to them such something from another vehicle that'll fit? I've noticed they have them but apparently not for my zj. I have a auto zone, advanced auto and a napa if you have part numbers for it.
Thanks,
Ian
iann32 is offline
post #12 of 16 Old 05-12-2014, 09:52 PM
big98tnzj
Thanks,
Ian
If you can wait you can get them both from rock auto for around $20 or a little more.
Sent from the mtns of TN using JeepForum
big98tnzj is offline
post #13 of 16 Old 05-13-2014, 09:23 PM
iann32
i just wanted to see if anyone knew off hand. looks like ill just order them. Thanks!
iann32 is offline
post #14 of 16 Old 05-13-2014, 09:29 PM
big98tnzj
Ive looked in about all of the parts stores and they have had to order them and they are more and individually sold. Rockauto is cheaper and im pretty sure they were moog brand or ac delco
post #15 of 16 Old 05-14-2014, 06:25 AM
iann32
ya ive check too. The ones from rockauto are were like $30 shipped for 2. (ordered a second incase the other gives me an issiue when i lift my jeep in a few weeks). And the ones from zone offroad were like $40 shipped for the kit with 2. And yes the ones from rockauto were moog.
iann32 is offline
