Control Arm Bushings Tool - Page 2 - JeepForum.com
post #16 of 22 Old 06-29-2013, 09:58 PM
KJK
Originally Posted by MasterOne View Post
What I was asking, is what is different about the uppers on the differential end? Are getting those bushings out a different process? It's not obvious to me, because I've never done this job before.
The bushings on the axle end are pressed into the axle housing instead of being pressed into the arm itself.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #17 of 22 Old 06-29-2013, 10:03 PM Thread Starter
MasterOne
This is what I was assuming. Can I get the control arm off of the vehicle without removing the bushings off the axle housing? What is the proper way to get the bushings on the axle end off and then back in? Swinging a hammer with barely any room doesn't sound like a recipe for success.
MasterOne is offline
post #18 of 22 Old 06-30-2013, 04:56 AM
AVR2
Yes. You just unbolt the arm as normal.
The factory-approved method is to use an uber-expensive Miller tool, but you can achieve the same result with a balljoint press. If you have an impact gun to turn the screw, you can get the rubber out in seconds. See the video below for more info.
Other than that, you can drill the bushing out, burn it out, hammer it out, whatever.
AVR2 is offline
post #19 of 22 Old 06-30-2013, 07:47 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
The miller tool I got off ebay wasn't bad but new, yeah its not cheap. But it sure was easy. No heat, hammering, just tighten the force screw and it popped right out. It worked kinda like this one...http://www.ebay.com/itm/American-Mus...ed13a4&vxp=mtr
By using a short piece of pipe, some fender washers, all thread rod ect some jeepers have fabbed a tool to work.
Originally Posted by HighLonesome
coralman is offline
post #20 of 22 Old 06-30-2013, 06:44 PM
Area11
When i did my front end bushings (entire front end) i used a torch to burn them out,i then used a wire wheel and drill to get the excess rubber out of the holes.
I still need to do the rear end. Its a ***** either way.
Area11 is offline
post #21 of 22 Old 07-01-2013, 07:38 AM Thread Starter
MasterOne
Thank you to all who have answered my question. I will get back with hopefully pictures and a video after I'm done.
post #22 of 22 Old 07-01-2013, 04:29 PM
coralman
coralman's Avatar
Here are pics of that on a 2wd using the miller tool, you can fab up some stuff and accomplish the same thing. Look at post twelve.
http://www.jeepforum.com/forum/f13/c...build-1518536/
coralman is offline
