Control arm bushings,which one goes where ??see pic - JeepForum.com
post #1 of 15 Old 03-16-2012, 04:21 PM Thread Starter
hdrocknroll
Moog Rear lower Control arm bushings came today ,but the two in each box it different.
I assume one goes on the front and one on the back of control arm but which one goes where??
Will I be able to tell by looking at the old one when I get it off ??
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #2 of 15 Old 03-16-2012, 06:22 PM
Oldfrog
2007 WK
If they are anything like the front lowers, the widest ones go on the body side of the control arm....at least on my 97 they did.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 15 Old 03-16-2012, 06:55 PM
newfieZJ
The slotted ones go to the axle side . Make sure the slots are approximately in the 9 and 3 position when installed , it's to absorb the bumps . Yes , you will see the replacement set-up when the arm is removed .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #4 of 15 Old 03-16-2012, 09:22 PM
vegasZJ
^^^ what he said.
When in doubt throttle out!
vegasZJ is offline
post #5 of 15 Old 03-16-2012, 09:37 PM Thread Starter
hdrocknroll
Thanks for the replies
They were in bad shape
Man !! these are a PITA they don't like to come out.
Got one done, and, I did position slots at 9 and 3
Came in to check torque specs
Edit: 130 FTLBS almost forgot I have to set it down before tightening
post #6 of 15 Old 03-16-2012, 09:52 PM
vegasZJ
vegasZJ is offline
post #7 of 15 Old 03-16-2012, 09:53 PM
vegasZJ
Watch that video the guy makes it look easy. I have aftermarket arms so it didnt work for me i had to use a press
vegasZJ is offline
post #8 of 15 Old 03-16-2012, 10:13 PM
newfieZJ
Glad you liked my video
newfieZJ is offline
post #9 of 15 Old 03-16-2012, 10:28 PM
vegasZJ
So you know with that video you saved my DDs life! I was going to blow it up!! Worked on the DD but not the rock toy
vegasZJ is offline
post #10 of 15 Old 03-17-2012, 01:00 AM
Oldfrog
2007 WK
I didnt want to hassle with mine. Just bought the cheap replacement arms for $23 each from Rock auto. A little PB blaster the day before and presto ! They came right off. Bolted the new ones on and we're good to go. Have to do the front uppers this next week...which is a PITA, from what I can tell, since the axle side has the bushing in the axle housing and not the arm itself.
Oldfrog is offline
post #11 of 15 Old 03-17-2012, 01:38 AM Thread Starter
hdrocknroll
Did you all notice in the video,that control arm actually had some paint still on it. No way was it as old and rusted, screwed up as mine were.
I was afraid to do very much pounding on them cuz that control arm metal is not very thick, I didn't want to bend them up.
Edit: the video came too late anyway.
Anyway the rear lowers are done.
Did some drilling on the rubber part, a little cutting on the metal part and they came out.
I don't think I want to do that again though, just a little more money I'll by the whole dam thing.
I guess I must have been blind before because in the pic below. I think I found my rattle,spring is hitting on the frame.
Next thing is, how does this spring seat thing come off ???
post #12 of 15 Old 03-17-2012, 06:54 AM
jr4x4
it should pull right off after removing the coil spring.
jr4x4 is offline
post #13 of 15 Old 03-17-2012, 07:16 AM
1stblack97ZJ
Yep
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #14 of 15 Old 03-17-2012, 08:51 AM
vegasZJ
It worked on my DD just not my dirt toy. The DD has 256,000 miles. For the upper on the axle side i punched a hole in it with a chisel then used a pry bar.
vegasZJ is offline
post #15 of 15 Old 03-17-2012, 09:00 AM Thread Starter
hdrocknroll
Ok , so its a spring isolator, I just pull off and replace.
Do I have to take off axle end of track bar,sway bar links and bottom of shocks ,or any thing else,to get the spring out ??
Is it screwed up just cuz its old n rotten ?? other side looks ok
control arm
Control Arm Bushings steeleman3 ZJ Grand Cherokee Forum 56 03-22-2012 08:05 PM
Control Arm bushings ejschultz ZJ Grand Cherokee Forum 4 03-31-2011 12:23 PM
Control Arm Bushings Justo609 ZJ Grand Cherokee Forum 4 02-25-2011 12:33 PM
Control arm bushings 02Lightning ZJ Grand Cherokee Forum 13 08-10-2010 08:23 PM
Control Arm Bushings TheAngus ZJ Grand Cherokee Forum 5 10-25-2006 01:11 PM
