Control arm bushing problem. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Control arm bushing problem.
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 02-27-2011, 05:24 PM   #1
AJB1985
Ok first off i have a 94 zj V8 with a np242. It has a Rock Krawler triangulated 4 link set up in the rear. Now before you tell me rock krawler sucks i know already. It was on the jeep when i got it. The problem im having is that the rear upper control arm bushings on the frame side are toast and makes so much noise. I was wondering if anyone here could tell me where i can get bushings for these arms. I tried rock krawler and they said they dont make them anymore. If i can't get these things im screwed because it has the welded in truss on the rear, so if i can't find them im gonna have to replace the rear end then get some adj arms
AJB1985 is offline   Reply With Quote
Unread 02-27-2011, 07:36 PM   #2
bigb229
if they are poly bushings...or you can get a measurement of the bushing housing...ID OD...etc....you can contact energy suspension and they can hook you up....or they may have some cut already....energysuspensionparts.com
bigb229 is offline   Reply With Quote
Unread 02-27-2011, 07:53 PM   #3
ratmonkey
Living dead mod
ratmonkey's Avatar
how about you call ROCK KRAWLER. at least they're still in business.
for the record, bushings in upper triangulated arms wear out VERY quickly. it's not a proper use of a bushing.
ratmonkey is offline   Reply With Quote
Unread 02-28-2011, 07:05 PM   #4
bigb229
pretty sure if you'll read...he said he's already talked to rock krawler...
Unread 03-02-2011, 03:59 PM   #5
AJB1985
Yes, i did talk to rock crawler and they told me the lift i have has been discontinued and the bushings have been also. Time to rip her apart and take some measurements i guess.
