Did fluid change days ago. took 7Q out. put 6Q in. Checked the level and it shows this. both side will show different level no matter what side i put in.
The one with the lower level has solid mark. while the other has higher mark but not as solid.
DID THE READING WHILE THE ENGINE IS RUNNING AND IN NORMAL TEMP, WHILE SHIFTER IS IN NEUTRAL.
Now my question is which one is the right reading. THANKS
(trying to make the question brief, not using to much word)
