Confirmation for WJ front driveshaft swap... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Confirmation for WJ front driveshaft swap...
Bds fox ipf 2.0 racing series shocks now available at rockIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Lockers FREE SHIPPING Excellent Prices
Unread 11-24-2009, 09:34 AM   #1
kwb18
I've researched this topic for the last day and believe I have my answer and resolution but I just want to make sure I haven't missed anything during my search.
I have a 00 WJ I6 with a 4 inch lift. I have the stock front drive shaft on it which is a CV at both ends with boots on both as well. This will be the 2nd time I've had to replace this.
So, as I researched here, I read that any 02 WJ or newer has a different drive shaft that has a Single u joint @ the diff and a double @ the TC? I also read that I will need a new yoke at the axle end but not at the TC end? I've read a lot about the torque specs for the crush sleeve and how not to mess that up.
Is all of my research correct? Or did I misunderstand something?
Thanks for the help guys!
00 WJ Laredo. 4" lift. 32 BFG MT.
kwb18 is offline   Reply With Quote
Unread 11-24-2009, 10:26 AM   #2
xJoshxx
2011 WK
your correct but you missed 1 Piece of Information.
Call up Carolina DriveShaft they make a Single/Double with flanges that Direct swap into the Transfer case as well as the Axle yok problem solved.
Interested in Amsoil? Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 Laredo with ORA1
xJoshxx is offline   Reply With Quote
Unread 11-24-2009, 10:35 AM   #3
kwb18
I've called up carolina driveline and they are pretty expensive. The Jeep is my DD. Well not even that. It pretty much sits in the driveway for the most part cause I walk to work. I live like a minute away from my office. So I'm just looking at doing an upgrade that will last but is not on the expensive side. Thanks for the info!
Unread 11-24-2009, 10:42 AM   #4
tsconver
2003 WJ
define expensive? Spending $400 on a Carolna shaft that bolts in without mucking with the dif yoke, or not gettingthe dif yoke set properly and replacing the front gears in 5000 miles cause they are toast from inproper pinion nut torque, about $500 or more depending on mechanic.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
My Build Thread
A few goodies
http://s257.photobucket.com/albums/h...umb55839/jeep/
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
http://www.zrxoa.org/
2006 Red Liberty
Wife's ride, pretty stock
http://i257.photobucket.com/albums/h...mage0008-1.jpg
http://www.cnc4x4.org/
http://www.treadlightly.org/
tsconver is offline   Reply With Quote
Unread 11-24-2009, 10:45 AM   #5
GraKee99
Rapist Wit
GraKee99's Avatar
You lifted your jeep to 4", things start to get expensive at that height. If you wanted to stay lower on the budget, should have went with a smaller lift.
Get the correct driveshaft the first time and you won't have to deal with it again.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote
Unread 11-24-2009, 11:24 AM   #6
kwb18
Thanks for the info! I thought the carolina one needs new yokes as well. At least that's what I was told a few months back when I called them. Maybe I misunderstood what was said. So the carolina one from what you're saying is a direct fit. Unbolt the old one, throw that POS in the garbage and the carolina one bolts right in?
Nevermind. I just gave them a call and I got all setup with the info. Thanks again guys! I appreciate it!
Unread 11-24-2009, 11:30 AM   #7
GraKee99
Rapist Wit
GraKee99's Avatar
That is what it should do. They are able to make those. Call them and talk to them. Tell that you a direct replacement where you don't have to replace the yokes.
Brian
WJ, WK, CJ5
Unread 11-24-2009, 11:31 AM   #8
Bama_WJ
Bama_WJ's Avatar
Yea, you tell them the setup you got right now and your lift height and they will send you a driveshaft with flanges that bolt right up. No need to buy new yokes or anything. Carolina quoted me $300 for the same setup your wanting.
Either that or go raid your nearest junkyard to try and find some C4C WJs with a DC driveshaft.
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Newest Addition: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel.
facebook. - Wheeling pictures and videos.
The Jeep Wave. Bringing it back.
For Sale Now:
- WJ JKS Shock Conversions
- OEM WK Springs
Bama_WJ is offline   Reply With Quote
Unread 11-24-2009, 11:45 AM   #9
(OllllO)
One thing to keep in mind is that the adapter yoke from the diff is not as strong as a regular u-joint style yoke and if you break one you can't just pick one up at NAPA.
(OllllO) is offline   Reply With Quote
Unread 11-24-2009, 12:10 PM   #10
xJoshxx
2011 WK
if you snap that adapter yoke you were abusing your rig.
atleats 3-4 people on here have that adapter have wheel with it No problems
Unread 11-24-2009, 01:15 PM   #11
(OllllO)
I'm not saying its junk, just pointing out a few pros and cons that weren't mentioned. I had Randy at Carolina Driveline build me a shaft recently, which BTW is a quality made shaft made to specific length. I asked him alot of questions about what my options were. He said I could get the bolt on an go route(cv style yoke adapter) or I could get a u-joint style yoke. He said the u-joint style is stonger and I could easily get one at any parts store incase I needed one. Your right, if your breaking that yoke you are running too hard in most cases. You could easily drop off a rock and break one too. If your out somewhere where you have to have 4wheel drive to get back out then your gonna be glad your buddy can go down to the parts store and get one instead of having a special yoke sent to you from S. Carolina.
Unread 11-24-2009, 01:39 PM   #12
zippome
well i was in your situation. i had busted 2 cv shafts and was fed up. i got a front shaft from an 02 and both yokes for 90 bucks. swapped them out and everything has been fine since then. just make sure you torque the pinion nut correctly or you will have some big problems like tsconver mentioned.
Im 20 with a 2000 Grand SOLD!
4" Zone Offroad Kit, 16x7 Cragar Soft 8's, 265/75/16 Maxxis Bighorns, Rock-It Sliders, Rancho SS, Yakima Load Warrior, Flowmaster Super 40, Reverse Lights, 2 Lights Up Front, Custom 6 Switch Plate, Cobra 76 XTR CB with PA, Lightbar, Custom Hitch Tire Carrier, Fleabay Warm Air Intake
zippome is offline   Reply With Quote
Unread 11-24-2009, 01:49 PM   #13
(OllllO)
I would have went that route but have too much lift. That would probably be your best bet kwb18 since its your daily driver and your only 4"s of lift.
Unread 11-24-2009, 02:07 PM   #14
kwb18
I've researched to pinion nut specs and I believe I'm set. Some really good info on this site for that.
