Computer Screen - Page 2 - JeepForum.com
post #16 of 21 Old 04-14-2013, 03:38 PM Thread Starter
SuperStew11
Originally Posted by KoreaZJ
Check for correct bulb types...
EXTERIOR LAMPS
Back-up ..................................1156
Center High Mounted Stop Lamp .............921
Fog.........................................H3
Front Turn Signal ......................1295NA
Front Side Marker .......................194NA
Headlamp/Aero ...........................H6054
License Plate .............................168
Rear/Stop/Tail ...........................2057
Rear Turn Signal .........................1156
Underhood Lamp ............................105
There is also a smaller 194 bulb on the side for the brake lights, which I now believe are the ones that are burnt out
SuperStew11 is offline
post #17 of 21 Old 04-14-2013, 05:48 PM
flexyxj
2009 XK Commander
Sometimes if the bulbs aren't the same type/ brand you will get a message from the VIC indicating that there's a bulb out when there isn't......
flexyxj is offline
post #18 of 21 Old 04-14-2013, 06:08 PM Thread Starter
SuperStew11
I could understand that, but just double checked and the 194s are out, and I had put so 194s in the upper light, so just got 921s so I'm going to put the 921s up top and move the 194s into the break lights and hope that fixes it
post #19 of 21 Old 04-23-2013, 09:10 AM Thread Starter
SuperStew11
So got my bulbs switched around and everything back to normal, thanks for all the help guys.
And does anyone have a problem with the computer screen always resetting its self like the power went out? Just realised that just stopping the time from flashing the VIC woulda told me "Rear Lamp Failure" and woulda saved me the dumb question of posting on here lol
But now I know..........and knowing is half the battle
post #20 of 21 Old 04-23-2013, 09:30 PM
kachink
I had a problem with the VIC resetting at random times on startup. Turned out to be a weak battery. It always started quick so I didn't notice (until it wouldn't start at all!). I think the voltage dropped low enough to reset it while it was cranking. When it happened it also wouldn't hold idle for a minute after starting without giving it some skinny pedal. New battery solved both problems.
kachink is offline
post #21 of 21 Old 04-24-2013, 07:22 AM Thread Starter
SuperStew11
Ya mine cranks over well and never had a stalling issue, it can hold idle for as long as it wants
