computer reset - JeepForum.com
post #1 of 9 Old 04-03-2009, 05:02 PM Thread Starter
yj35s
computer reset
I have a 2003 WJ that the check engine light was on. So I reset the computer to get it inspected. How many miles do you have to go for it to clear the OBD system. I have gone 80 miles and the Evap and 02 Sensor still have not reset. THANKS
-1990 Wrangler- 5 inches, 35x12.50, chevy 350, 700R4, line-x tub
-2003 Grand Cherokee- 2''BB and 265/75 BFG all-terrain (daily driver)
yj35s is offline
post #2 of 9 Old 04-03-2009, 05:03 PM
baxy
what are you using to reset and to read the status of the monitors?
baxy is offline
post #3 of 9 Old 04-03-2009, 08:41 PM Thread Starter
yj35s
I disconnected the battery to reset the computer. When I go to get the inspection and they hook there little box up to my port and the read it on the seperate computer screen it says that the computer hasn't fully reset yet. thats all I know about it.
yj35s is offline
post #4 of 9 Old 04-03-2009, 08:42 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
So you replaced the 02 sensor that the code was for and the code isnt going away after you reset the computer?
disconnect the battery fora little while
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #5 of 9 Old 04-03-2009, 08:44 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
or you can use an odbII scanner to reset it or it resets fully after 40 key starts.
post #6 of 9 Old 04-03-2009, 08:45 PM Thread Starter
yj35s
I disconnected it for like an hour and half. How many miles do you have to go for it to all register again?
yj35s is offline
post #7 of 9 Old 04-03-2009, 08:45 PM
baxy
each monitor has it's own parameters before it will run
the service manual sometimes tells you what the drive cycle is
the o2 monitor is the heater that is being monitored and the evap is going to run a test for leaks in the evap system
I'll look in the manual see if it gives the drive cycle for those monitors
baxy is offline
post #8 of 9 Old 04-03-2009, 08:47 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
It doesnt go by miles, it goes by 40 warm up cycles:
Originally Posted by wjjeeps.com
Erasing codes:
After three good trips the MIL is extinguished and the Task Manager automatically switches the trip counter to a warm-up cycle counter. DTCs are automatically erased following 40 warm-up cycles if the component does not fail again.
DTCs can be erased anytime with a DRB III. Erasing the DTC with the DRB III erases all OBD II information. The DRB III automatically displays a warning that erasing the DTC will also erase all OBD II monitor data. This includes all counter information for warm-up cycles, trips and Freeze Frame.
post #9 of 9 Old 04-03-2009, 09:01 PM
baxy
some systems need certain parameters to run the test , some systems are continuously monitored and some only run until the test passes and is not run again until the next time you shut down and restart..
I can't remember all the parameters for EVAP but one is a certain ambiant temp not too cold and not too warm,not too full of fuel and not below 15% EVAP can be forced with a scanner
O2 monitor is sometimes cold start on some models I think JTEC and others is at shut down SBEC but these parameters can usually be found in a manual it is different from manufacturer to manufacturer and sometimes model to model
baxy is offline
How 2 reset my computer- it says I need to perform service-which I just did myself mark.hoff ZJ Grand Cherokee Forum 9 10-30-2010 06:30 PM
ZJ Info Computer... How To ReSet a Service Warning? NIUPonyBoy ZJ Grand Cherokee Forum 12 04-20-2009 01:49 PM
Strange Mileage / Computer reset pulls2theright ZJ Grand Cherokee Forum 4 07-12-2008 07:44 AM
Reset computer GC4L2000 ZJ Grand Cherokee Forum 5 06-19-2006 05:37 AM
Reset computer??? Jungerishere ZJ Grand Cherokee Forum 2 07-27-2005 01:27 PM
