Computer replacement terminal pins (intermittent shut downs) - JeepForum.com
post #1 of 9 Old 08-16-2010, 10:27 PM Thread Starter
JS97ZJ
After searching everywhere for a fix for the problem of my engine shutting down intermittently that seems to effects mostly (96-98) JGCs, and after cleaning the PCM connectors then ty-wrapping a number of times. I found the solution for the bad pins.
The connectors use to be manufactured by Thomas & Betts and that division was bought out Tyco Electronics which only sell large quantities.
There are only two competitive companies that sell smaller amounts to the little people and both sites require a minimum order of $35. Since I suspect that if 1 or 2 of these pins are causing problems, chances are there will be others to follows. The big 3 all use the same pins in there vehicles and according to GM engineers once the connectors are taken apart more than 3x the connection can now be suspected as being a probable future problem. If you feel that your problems might be caused by this read on.................
The pins,
http://www.mouser.com/ProductDetail/Tyco-Electronics/3-1447221-3/?qs=MvPdH6bTHujBOZcRbVlrYA%3d%3d
http://www.onlinecomponents.com/buy/AMP-TYCO/3-1447221-3/
After removing the connector from the computer you'll notice a Blue plastic tabs incorporated into the sides of the connector housing. This is the locking slide that in hold all the pins. Pushing in on the blue slide (the side with 2 blue exposed pieces) will release the lock. The only thing holding the pins in now is a retainer that will hold the pins in until it's locked again after the repair is made. To remove the pin from the housing you'll need a pin extractor.
https://millerspecialtools.spx.com/Detail.aspx?id=247&gid=15
Sliding the extractor into housing around the wire/pin your trying to remove will release the pin retainer so the pin can be pulled out of the housing easily.
The next step will be of course crimping on the new terminal pin. The least expensive of the crimpers that I found that can be used for almost all of the terminal type pins in automotive wiring is availible though Radio Shack. If they don't stock it, get their store #, order it on line , and have it sent to there. No shipping charge and they,ll call you when it comes in. $10 bucks
The one I ordered though my local electrical / data wiring supply store cost alittle more but will cover many more types of connections D/D-sub., DoubleD, Insulated, none-insulated, barrel, top hat , that I also included the web site. Again if you get it though your local Electrical store though their distributor you could save $30 bucks.
http://www.radioshack.com/product/index.jsp?productId=2103683
http://www.aikencolon.com/D-Sub-Double-D-Service-Tool_c_888.html
For anyone who might feel alittle weary about doing this to their electrical system I also found a couple of videos on You Tube check it out...
I hope this info helps out as much as this web site has helped me.
Update: 10/10/12............This was the the first attempt at fixing the "dying while driving syndrome" The final fix that worked was in this next thread...
http://www.jeepforum.com/forum/f13/9...tures-1303589/
JS97ZJ is offline
post #2 of 9 Old 09-15-2010, 11:38 AM
iPlay1515
Excellent writeup.
iPlay1515 is offline
post #3 of 9 Old 03-19-2011, 08:41 PM
ZeeJay1997
Thanks!
ZeeJay1997 is offline
post #4 of 9 Old 03-22-2011, 01:55 PM
andrew520
(1996 4.0L) I removed all 3 connectors from my PCM. I see no blue tabs. Are you referring to the Black/White/Grey sections of the connectors? These are held on by 4 tabs (2 on top and 2 on bottom). If so, once that is off will all the pins still be held in place? Is it pretty obvious to notice which pins will need replaced also?
andrew520 is offline
post #5 of 9 Old 03-22-2011, 03:52 PM Thread Starter
JS97ZJ
All the info on locking the pins into the connector is here
http://dodgeram.info/tsb/1997/08-01-97.htm
Have you tried ty-wrapping the connectors to the PCM in order to resolve the problem with shutting off?
I have moved on to the inside of the PCM, after not being able to fix my symtoms after the ty-wrap trick failed and have finally solved it by re-soldering the circuit board. (I haven't done a write up yet) still taking pictures.
JS97ZJ is offline
post #6 of 9 Old 03-23-2011, 08:46 AM
andrew520
Thanks a lot for that link. The zip-ties worked when I first started having the problem over a year ago. Now it's getting a bit worse and new zip-ties aren't solving the problem. I was also thinking that maybe by wiggling the plugs causing the stall that it could be a bad solder in the PCM and the wiggling is moving the board and that's where the problems are coming from. I haven't taken apart the PCM to look at the board because I've read that you can't see it as it's encased in some kind insulator silicone or something?
post #7 of 9 Old 03-23-2011, 09:48 AM Thread Starter
JS97ZJ
This is what it looks like inside. This pic is part of the write up I'm in the process of doing. Because this junk inside is a problem that must be dealt with, coming up with the best method and explaining it without frightening others into not attempting it, is taking time. Plus I'm trying to put it through what I would consider a final test so I don't look like an a**.
JS97ZJ is offline
post #8 of 9 Old 02-08-2012, 04:11 PM
henrygeorge
a big part of the problem are not the pin themselves but the plastic tabs holding the pin stable. the blue plate locks the wire in place and partially holds the pins stable, but the plastic tabs hold the pin itself stable. the plastic tabs become brittle and are fragile. if you disassemble the connector to replace the internals of the connector, you need to force and break the pins loose from the plastic tabs. if you cut a replacement connector from the junkyard, you can carefully push the wire from the junkyard connector with the grain of the plastic tabs, though you still threaten the integrity of the connector. you have to get the wires in correct or you'll need another connector if you must pull the wire back out. crimping the pins to make sure the pin themselves are not loose would probably be wise as well, and is probably something i overlooked when attempting this method. it takes longer, but splicing, soldering, and shrink tubing the wires of a replacement junkyard connector to the wire harness would be the best route to take without the need to make sure the integrity of the connector is not made worse by attempting to replace the internals and crimp the pins.
henrygeorge is offline
post #9 of 9 Old 01-23-2015, 02:14 PM
Russell9dewayne
I need to remove all 3 connectors from my 1999 Jeep wrangler to replace the PCM and would like to know if any one can tell me how to remove them with out breaking them ?
I can not tell how to remove them at this time.
Russell9dewayne is offline
cargo area tie downs.... bimmerjeeper ZJ Grand Cherokee Forum 4 08-21-2009 03:31 PM
Battery terminal clamps tbm5690 ZJ Grand Cherokee Forum 10 07-26-2008 10:56 PM
Battery terminal replacement 3fifty ZJ Grand Cherokee Forum 12 09-16-2007 03:24 PM
Lookin for some hand-me-downs ZJMike0932 ZJ Grand Cherokee Forum 1 11-29-2006 09:00 PM
Terminal Clamp Removal mr_user ZJ Grand Cherokee Forum 7 10-12-2004 04:34 PM
