Computer MPG - JeepForum.com
post #1 of 5 Old 12-19-2004, 04:57 AM Thread Starter
gregoryc.
Computer MPG
Anyone know what the onboard computer uses to calculate the instant mpg? I would assume it uses engine rpm, throttle position and mph. Also, how accurate is it? I have a 2000 GC Laredo and it tacks about 2000, 2100 around 70 mph. Is that too high.
Thanks
gregoryc. is offline
post #2 of 5 Old 12-19-2004, 07:47 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Your onboard computer uses the inputs from the ECU that calculates fuel flow based on demand and some other parameters that I get paid not to tell you.
Very top secret.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 5 Old 12-19-2004, 08:41 AM
jeepholic
jeepholic's Avatar
Can you give us a hint if it has anything to do with wheel rotation?
Does the sliding scale speedometer due to tire size change effect the computer MPG reading?
I use a Jeep
You drive a car
Big difference.
94 I6 ZJ at 4", 33's and front locker and 4.11 gears. Swampy Bypass.
Black Jeep Club Member Ver. 2 #51
jeepholic is offline
post #4 of 5 Old 12-19-2004, 08:46 AM
Stocker
Very top secret.
Hunter
Hah! Very good, Hunter - I'll use that line next time I don't have the exact answer, lol!
Gregory, some have said their computer's mpg reading is inaccurate, but mine been spot-on every time I've checked it. I'd suggest doing the math a few times to see how yours is.
Back to Hunter - I see Nick's email addy in your sig is different from what I've used (Kolak@aol.com) - has he changed it, or will either one work? Thanks...
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #5 of 5 Old 12-20-2004, 01:30 PM
Dacaur
Dacaur's Avatar
2008 MK Patriot
Yes, it has everything to do with wheel rotation. Basicaly all it does is take the amount of fuel you are using at any given point and calculates your instant MPG based on how fast you are going, thats what your MPG would be if neither of those 2 imputs changed..... Thats why you get 0 instant MPG when you are stopped, and you can get 99 instant MPG when you have it idleing on a steep downhill.....
Dacaur
99 WJ Laredo
2.5" Budget boost, 265/75/16 tires, K&N air filter
Past Jeeps:
1992 YJ 4.0, 5 speed 6", lift 33's
1992 XJ 4.0, auto, 3" lift, 31's
1999 XJ 4.0, auto, 3" lift, 31's
1985 XJ 2.5, 5 speed, no lift, 255/70/15's
Dacaur is offline
Sensor goes off, sends signal to computer, computer sends it to my odometer... ef1992 ZJ Grand Cherokee Forum 2 07-20-2009 01:33 AM
98 computer in a 97 ZJ Zak62592 ZJ Grand Cherokee Forum 5 05-21-2008 04:34 AM
Computer kwsamms ZJ Grand Cherokee Forum 10 01-26-2008 01:47 PM
Is it the computer? beagoodo ZJ Grand Cherokee Forum 9 03-06-2007 10:27 PM
Computer drewguere ZJ Grand Cherokee Forum 7 02-10-2007 10:06 PM
