01-11-2008, 06:36 PM
#1
Computer/Clock Resets by itself
Hello everyone,
This morning, when I tried to start my car (Grand Cherokee 1997), the Computer apparently reseted by itself and the date/clock went back to jan/01 12AM. I tried to start it again but It wouldn't work.
I checked the battery, and it was fully charged, the temperature warm (70f), and I dind't hear any strange noise coming from it...
So, a few minutes later I tried again, but this time I gently pumped the gas pedal.This time the car finally started, but I had to keep holding the gas pedal for a while so it wouldn't die.
After a few minutes, it started to work again and I dind't have the start problem for the rest of the day (I turned it on and off several times during the day). However, this evening, When I tried to start the car, it worked, but the Date/Clock has been reseted again.
Does anyone have a clue of whats happening?
Thanks
Alvaro
01-11-2008, 06:55 PM
#2
are you talking about the VIC below the heater controls? That tells when a door is ajar and such? If so..my friend had a simular problem and it was the battery getting low, not low enough to not start or anything, but just below a certain amount of voltage that it would cause that to reset, I had a simular problem in my 95 limited. It started by it resetting here and there, then it would go black completely, then work but be reset, basically whatever it felt like doing. I'd so double check your battery, if it keeps happening or gets worse like mine did then it may be the VIC itself that needs to be replaced, not really a big deal and can usually be found on ebay for a decent price, just make sure you get it for the right year. 93-95 was different then 96-98, or else I'd be able to sell you one I have, but its for a 95, one of the parts I kept from it after I rolled it.
01-11-2008, 07:04 PM
#3
Exactly how did you check the battery?
I would start by removing the battery cables and clean them and the posts.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
01-11-2008, 07:11 PM
#4
I thought someone here took it apart and resolder some wires inside the vic..
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
01-11-2008, 07:22 PM
#5
Note: a common mistake is to place a voltmeter on the battery when the engine is running, and think that you are measuring the battery voltage. You are not measuring the battery but instead are measuring the output of the alt.
Charging voltage. With the engine running steadily, A reading between 13.2 volts and 14.8 volts indicates a good alternator! A reading of less than 13.2 volts is a sign of a bad alternator or voltage regulator; a reading of more than 15.6 volts is a sign of a bad voltage regulator
Cheers Steve
01-12-2008, 04:05 AM
#6
X2.................
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Latest Pics
01-12-2008, 04:25 AM
#7
Headed Out West
X3........... I remember one time running out with the shotgun because my alarm was going off. Looking around like WTF. Shrugged shoulders went back inside after re-arming (the security)  Fell back asleep , and guess what happened next ?
01-12-2008, 09:16 AM
#8
Senior Moment Member
the clock resets when the battery, alt, or charging system starts to fail. Typically, its the battery. second most common problem is corroded or loose cables. Clean the connections, check the cables for corrosion. have the battery and alt checked by Sears, Autozone, or similar place. if all that is OK check for a electronic device that isnt turning off or shorted.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links: Kevin (AKA KOR) for ZJ & WJ stuff,
Kolak for performance stuff. I6 performance info at Dino's jeep 4.0 performance site
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
01-12-2008, 09:23 AM
#9
It will re-set it self if Battery voltage drops below like 9.6 - when you hit start all the power is "GO"ing to the starter & when voltage comes back up you have to set your clock...
98 ZJ Laredo - 5.2 - 33/12.5 Kevlar MT/Rs - JKS(Modifide)Quicker Disocs - www.KevinsOffRoad.com - LP-1 SliderZ/ (*X-Member Skid*4-sale*) /Light bar w/Remote Lights - 2.25+3.5 RE Lift - Cobra Ultra lll w/FireStick - Bomb - XJ Front DS - Red-top - 10k winch w/Wired & Wireless - Aussie - Flex-a-lite - Garmin - www.ironrockoffroad.com - Iron-Y 3-link - Auburn E-locker - & A GREAT DANE Hangen out the window... GOT GAS??? Lets "GO"...
01-14-2008, 09:22 AM
#10
Mine has been doing this same problem for years i jus ignore the thing i have thought about takin it out but it does have some usefulness like overheating but i see that on my gauge. I had a 4 wheel drive problem also i might still i forget its jus pointless to fix you prob will get one that will break again they took the VIC out because they had these problems in 96 i think and changed it and then completely gone in 99. There is a reason for it and it was because they were terrible and pointlessand cool looking for back when the ZJ first came out
94 ZJ I6 Second 4.0 as of 226k Aftermarket Intake, Flowmaster 40 series, Rear Discs
05 Kawasaki Ninja ZX-6R 636 just ridiculously fast
96 Nissan Altima 5 speed stock and probably keepin it that way aka the beater or commuter car who wouldnt buy it for a grand with how gas is
