Is it the computer? - JeepForum.com
post #1 of 10 Old 03-06-2007, 11:38 AM Thread Starter
beagoodo
Is it the computer?
My 96zj has had a lot of issues starting in the last month. It just cranks and cranks and cranks...
So i replaced the starter and the alternator. THat didnt work so I called in a mechanic and he replaced the ignition coil. That didnt work so he then replaced the crank sensor.
Two days later it did the same thing... turn key crank crank crank... So i called the same guy and he said it is probably the computer? Any thoughts?
~OIIIO~ Jeep Girls Do It In The Mud!
beagoodo is offline
post #2 of 10 Old 03-06-2007, 01:03 PM
Wiley
Wiley's Avatar
Test pressure at the fuel rail next. The pump might be on its way out.
It could very well be the PCM (computer). I had the same starting problem. The capacitors in mine were dying. I replaced them for less than $5. Now it starts up every time.
Justin
1993 ZJ Laredo
5.2 V8 4" lift 31s JKS f & r track bars JKS discos Cragar Soft 8s DT 3000s OME Stabilizer
K&N drop-in Dynomax Exhaust Hella 500s Westin Safari Bar KOR Radiator Support
Dark Rosewood Jeep Club Member #5
Wiley is offline
post #3 of 10 Old 03-06-2007, 01:08 PM
Wiley
Wiley's Avatar
Check out this thread for the PCM fix.
Pics are on page 2.
http://www.jeepforum.com/forum/f13/bad-ecu-pcm-help-330109/
Justin
1993 ZJ Laredo
Wiley is offline
post #4 of 10 Old 03-06-2007, 01:17 PM
boilinsrt
1) See if you are getting spark
My favorite way is a shot of starting fluid, easier than pulling a plug and all that jazz
2) See if you are getting fuel
a) Fuses first
b) Then relays, switch it out with one with the same part number with something that you know works
c) Check fuel filter. I've seen engines that won't start with clogged fuel filters
d) Fuel pump have a buddy sit by the fuel tank and listen to see if he can hear the fuel pump turn on when you turn the key to on but not turning it over.
3) Then there is the all the odd ball stuff like holding the pedal to the floor and turning it over if the tps sensor is bad.
Should be a good start for now...
boilinsrt is offline
post #5 of 10 Old 03-06-2007, 01:39 PM
John in MA
1994 ZJ
Pics are on page 2.
http://www.jeepforum.com/forum/showthread.php?t=330109
The 1996-1998 ZJ's used a completely different PCM, both in function and appearance. I haven't heard about similar problems with those, if there were those directions wouldn't apply other than in a very general sense.
John in MA is offline
post #6 of 10 Old 03-06-2007, 01:43 PM
Wiley
Wiley's Avatar
Derp. I didn't even notice he has a 96. My mind is stuck in the olden days, as in pre 96.
Justin
1993 ZJ Laredo
Wiley is offline
post #7 of 10 Old 03-06-2007, 03:58 PM
John in MA
1994 ZJ
The good old days. Real Jeeps use the AMC typeface on the front fenders.
post #8 of 10 Old 03-06-2007, 10:17 PM
Gizimomo86
mine died on me a few months back - computer said it was the distributer, but after replacing it and everything I could think of, why not the crank sensor? yeah - that did the trick. Ive learned never to trust the computer LOL
Gizimomo86 is offline
post #9 of 10 Old 03-06-2007, 10:23 PM
John in MA
1994 ZJ
What did the computer actually say in that case? ie: what code?
post #10 of 10 Old 03-06-2007, 10:27 PM
Gizimomo86
I cant remember what codes it gave me, id have to go back outside and check it - I had my dad helping me, which turned out to be more money for me in the long run LOL - after that my husband had enough and had it towed to my mechanic lol
Sensor goes off, sends signal to computer, computer sends it to my odometer... ef1992 ZJ Grand Cherokee Forum 2 07-20-2009 01:33 AM
98 computer in a 97 ZJ Zak62592 ZJ Grand Cherokee Forum 5 05-21-2008 04:34 AM
Computer kwsamms ZJ Grand Cherokee Forum 10 01-26-2008 01:47 PM
Computer drewguere ZJ Grand Cherokee Forum 7 02-10-2007 10:06 PM
Computer MPG gregoryc. ZJ Grand Cherokee Forum 4 12-20-2004 01:30 PM
