Computer - JeepForum.com
post #1 of 8 Old 02-10-2007, 08:32 PM Thread Starter
drewguere
drewguere's Avatar
Computer
My girlfriend has a 2003 Grand Cherokee with the 4.0L
Her jeep died yesterday and the tow guy said it was the computer.
How hard is this to replace?
Im not gonna be doing it either way because its hers but if I ever need to do one Id like to know what Im in for
2002 GMC 2500HD 8.1L - Tow Rig
1998 Jeep Cherokee - Wheelin Rig
1988 Jeep Wrangler - In progress...
drewguere is offline
post #2 of 8 Old 02-10-2007, 08:39 PM
cmonson
Get the codes first before you replace anything. How would a tow truck guy no anything on the spot like that?
COuld be anything without hearing any details.
When an engine does not run it is usually only 1 of 2 issues going wrong.
Either there is no spark, or no fuel.
I really doubt it is the computer.
cmonson is offline
post #3 of 8 Old 02-10-2007, 08:41 PM
greasefingers
greasefingers's Avatar
1994 ZJ
This thread is useless without pics ... of your gf. Just kidding.
And so the tow gut showed you his credentials in mechanics?
No a 2003 ECU would almost never be the first thing to brain storm about.
No fuel, faulty battery, and a dead crankshaft position sensor are the most common things that cause a Jeep to die.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 8 Old 02-10-2007, 08:44 PM
greasefingers
1994 ZJ
cmonson has a good point Ö pull the codes.
Try both methods in this order (even though hers is a OBDII)
Older (OBDI) models - Start with the ignition off. Within five seconds, switch the key (without starting the engine) on, off, on, off, on. ("On" is NOT "Start" and "Off" is NOT "Lock"). The "check engine" light will flash. Count the flashes. Each code is a two digit code, so a (for example) 23 would be FLASH FLASH (pause) FLASH FLASH FLASH (long pause). It will never flash more than 9 times, so watch for those pauses!
Newer (OBDII) models - Put the key into the ignition, push down the odometer reset button, then turn the key to RUN with your finger on the button - and then release the button. The odometer will go through 1111111 through 999999, then display the car's serial number. It will then show the error codes (it might show them starting with P). If this method does not work, try the OBDI method.
Cheers Steve
post #5 of 8 Old 02-10-2007, 09:19 PM Thread Starter
drewguere
drewguere's Avatar
Well it wasn't the tow guy right on the spot. They towed it to their shop, checked it out, she thought it was her alternator because that went out on her GMC and it was similar (electrical probs) then they checked it at their shop and said it was the computer, and towed it to the dealer to get it done...
...the same dealer thats ripped my mother off numerous times, and now her car has a blown motor because of their ignorance.
And of course...
Shes jailbait til the 21st...so dont get any ideas
post #6 of 8 Old 02-10-2007, 10:11 PM
vendetta714
why would you post pictures of your girlfreind on a website....
2002 Jeep Grand Cherokee Limited, 4.7L Displacement Hight Output
vendetta714 is offline
post #7 of 8 Old 02-10-2007, 10:22 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
read the whole thread and you will know
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #8 of 8 Old 02-10-2007, 11:06 PM
ForwardControl
Girls that drive WJ's are hot!
quardatokn, I know I browsed past a thread here explaining how to swap out the PCM and the BCM or maybe it was two threads, but now I'm having search troubles...
If it does happen to be the PCM that needs to be replaced, or if you're still interested in this, do a search for "PCM" and see if you can find it - I know it's here somewhere, and it left me feeling like I learned something, so...
Matt
2000 WJ Laredo (Champaign), 4.0L, 242 SelecTrac. Added: Black front hooks. K&N FIPKII Intake. RB1 Navigation, Mopar iPod Integration. 31" BFG All Terrain T/A KO. Alpine audio upgrade (see link below). Next: IRO 3" Lift, new shocks.
I HAVE A 4.0L In My WJ And LOVE It So *** Me Club Member #1
Colorado Jeep Club Member #114
ForwardControl is offline
Sensor goes off, sends signal to computer, computer sends it to my odometer... ef1992 ZJ Grand Cherokee Forum 2 07-20-2009 02:33 AM
98 computer in a 97 ZJ Zak62592 ZJ Grand Cherokee Forum 5 05-21-2008 05:34 AM
Computer kwsamms ZJ Grand Cherokee Forum 10 01-26-2008 02:47 PM
Is it the computer? beagoodo ZJ Grand Cherokee Forum 9 03-06-2007 11:27 PM
Computer MPG gregoryc. ZJ Grand Cherokee Forum 4 12-20-2004 02:30 PM
