Completely sheered an axle-side rear driveshaft bolt - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Completely sheered an axle-side rear driveshaft bolt
Steering and more from Ruffstuff!Ruffstuff 3 Link Kit!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 10-01-2014, 06:13 AM   #1
solomon8718
Not sure why this happened - I ended up stranded yesterday and having to get a tow. I tightened the bolts as tight as I could when I installed it and used thread locker. Any of you able to shed some light on this? Hopefully Ill be able to recover the driveshaft.
solomon8718 is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 07:10 AM   #2
zjosh93
You may have overtightened the bolts if you tightened them as much as you could. They aren't very big and they are fine thread. The torque spec is pretty small.
zjosh93 is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 07:11 AM   #3
solomon8718
Well, honestly tightening them as tight as I could wasn't exceptionally tight. I actually struggled tightening them while avoiding rounding out the heads.
Unread 10-01-2014, 07:12 AM   #4
PolkaPower
I'm going to say over tightened as well. Those are small bolts and don't require a bunch of torque to tighten. You can easily break the heads off of them over tightening as well. I did that once. Same goes for the brake caliper bolts.
PolkaPower is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 07:24 AM   #5
solomon8718
So you guys are saying is I possibly weakened the bolt by over tightening?
Unread 10-01-2014, 08:34 AM   #6
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I was thinking the pinion angle was way off.
HighLonesome is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 08:40 AM   #7
PolkaPower
If it was that bad wouldn't you notice it while you were driving? It would probably feel like when my front CV shaft bit the bullet.
Unread 10-01-2014, 08:52 AM   #8
HighLonesome
I reckon so.
I torque those bolts pretty tight and never had a problem.
Unread 10-01-2014, 09:04 AM   #9
NTH
IIRC, torque spec for those is approx. 14-20 lb/ft
____________________________
1998 Grand Cherokee Laredo 4x4 // 5.2L // D30/44RE/NP249/D44a //
NTH is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 09:05 AM   #10
jlann
I don't think it was over tightening. Over tightening that would take a CRAP ton of torque.. Which I don't think would be possible using regular tools (I assume you used). I'd go over all of the compromised components and look for stress fractures and strain marks. I am a construction project manager (took engineering classes for the degree on materials + stresses and strains) and believe me, I don't think you by yourself broke that from over tightening.. It happens rarely.. but not in this context.
// 1997 Laredo 4x4 // 5.2L // 210,000 mi // Charcoal Grey //
jlann is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 09:06 AM   #11
jlann
This is my speculation as well ^
Unread 10-01-2014, 10:00 AM   #12
zjosh93
The U-joint strap bolts are 1/4-28 thread. A quick look around at suggested torque values for that thread and the average is about 10-14 ft/lbs. I'm pretty sure most of us with regular tools can break that easily.
Unread 10-01-2014, 10:11 AM   #13
solomon8718
Thinking back this may be it. I do recall a little vibration at higher speeds. And with the torque of the niner maybe even a small amount of pinion angle being off could rip that bolt apart especially if it was weakened over time.
Unread 10-01-2014, 10:19 AM   #14
PolkaPower
That is the front though. 90% of the power is to the rear until it slips. There is hardly anything going to the front. A little vibration would not constitute total failure. It would be a very apparent WHOMP WHOMP WHOMP and you would want to pull over immediately.
Unread 10-01-2014, 10:20 AM   #15
solomon8718
Well actually that is the rear drive-shaft that sheered off and it was in 2wd at the time (TC swap). There was no obvious issue until the shaft actually let loose which certainly caused a big whomp whomp whomp.
I would describe the vibration as a loud hum (maybe like a whum sound) mostly around 75+ miles an hour.
