Common ZJ Problems / Tutorial On How To Fix Them - Page 6 - JeepForum.com
 1Likes
post #76 of 283 Old 12-28-2012, 01:54 PM
jeepgirl1321
Jeep issues continue.....
same issue as before. jeep will die all the time, whether it be that I am driving down the road, or pulling in and out of parking spots. HELP.
adjusted the crank shaft positioning, reset the PCM, made a bracket to make sure wires dont wiggle out of computer.
running out of ideas on what to fix, all i can think of is a stick of dynamite..... any one else know what the hell is going wrong with the stupid thing???
jeepgirl1321 is offline
post #77 of 283 Old 12-28-2012, 02:12 PM
cgcarpenter
Replace PCM. End of story.
cgcarpenter is offline
post #78 of 283 Old 12-28-2012, 02:44 PM
ZeeJay1997
Need more info...
Does wiggling the PCM connections have an affect on the way it idles?
How did you adjust the crank sensor?
Your looking at a bad crank sensor or bad PCM
ZeeJay1997 is offline
post #79 of 283 Old 12-28-2012, 02:52 PM
joe_keefer
1994 ZJ
If the PCM proves fine. Test the crank sensor to see if its bad.
joe_keefer is offline
post #80 of 283 Old 12-30-2012, 12:28 PM
jeepgirl1321
replacing the pcm is my next step. and i went to jeep and had a tech adjust the crank shaft and of course he said that should fix it....
and before i had the bracket to prevent the wiggeling of the wires if you even thought about touching them it would studder and die.
post #81 of 283 Old 12-30-2012, 12:51 PM
ZeeJay1997
Snake oil!
post #82 of 283 Old 12-30-2012, 12:52 PM
970001zj
97 zj orvis/04 wj ltd/02 lancer oz rally/85 rx7 gs
970001zj is offline
post #83 of 283 Old 12-30-2012, 01:05 PM
jeepgirl1321
snake oil? hahahahaha
post #84 of 283 Old 12-30-2012, 01:20 PM
ZeeJay1997
post #85 of 283 Old 12-30-2012, 01:23 PM
joe_keefer
1994 ZJ
Supposedly it can be shimmed 1-2x. But for the cost it's best to just replace it.
post #86 of 283 Old 12-30-2012, 01:46 PM
ZeeJay1997
To shim it would put it further away from the flywheel, weakening the Hall effect.
I can see why someone would try to push it towards the flywheel to get a better output. The closer to flywheel it is, the better it works. This introduces the risk of damaging the sensor because the flywheel contacts it when the engine turns.
So any attempt to adjust it is guesswork that no one should have to pay for.
post #87 of 283 Old 12-30-2012, 01:54 PM
joe_keefer
1994 ZJ
So then are they shimmed to start with? Then removed as needed? I've never needed to mess with one. Just repeating what I've read.
post #88 of 283 Old 12-30-2012, 03:04 PM
LouC
2007 WK
They come with a paper spacer on the sensor end of the crank sensor (at least the OE ones do) that contacts the flywheel when you install it and when you start the engine the flywheel scrapes it off. That sets the gap to the proper distance. If you remove the crank pos sensor and reinstall it, you have to get another paper spacer (or fab one up) to get it set right.
My stalling problems on my ZJ went away when I had a new PCM installed.
LouC is online now
post #89 of 283 Old 12-31-2012, 05:01 PM
Jleming
I too had the same problems....I replaced the crank sensor, map sensor, spark plug wires, and cleaned the o2 sensors, and the iac... ended up just needing a new computer and starter....after those two fixes, haven't had any problems at all
Jleming is offline
post #90 of 283 Old 01-28-2013, 10:08 AM
theblackjack69
FYI, the 4.0 Timing Chain link goes to the fog light How to, somebody forgot to switch which link they copied lol
theblackjack69 is offline
