Common ZJ Problems / Tutorial On How To Fix Them - Page 5 - JeepForum.com
 1Likes
post #61 of 283 Old 12-05-2012, 05:34 PM
jeepgirl1321
Originally Posted by JasonStebbins View Post
Could be a number of things. What does it do when it dies?
Fuel pump/CPS/Alternator/Battery/TPS/Upstream oxygen sensor/ECM
Post some symptoms of what happens before/when it dies.
right before it dies, the rpm completely die. and i loose power steering. Its like the engine just dies. New alternator battery and fuel pump.. and sometimes it doesn't completely turn off, the rpm's will die down then come back.
any ideas? cause I'm lost.
jeepgirl1321 is offline
post #62 of 283 Old 12-05-2012, 05:42 PM
nwzj_jeeper
Did you reset the PCM?
nwzj_jeeper is offline
post #63 of 283 Old 12-05-2012, 06:43 PM
jeepgirl1321
Originally Posted by nwzj_jeeper View Post
did you reset the pcm?
pcm?
post #64 of 283 Old 12-05-2012, 06:50 PM
cgcarpenter
The thing in front of your coolant reservoir tank... It has three connectors on it.
When the jeep is running wiggle each connection one by one as see if the symptoms show...
I had the exact same problem on my 4.0 and I needed a new pcm
cgcarpenter is offline
post #65 of 283 Old 12-05-2012, 06:57 PM
nwzj_jeeper
Look it up you disconnect the positive battery turn te key 3 times off on off on off on and reconnect and it resets it. It clears the codes and re teaches the care to idle
post #66 of 283 Old 12-05-2012, 07:15 PM Thread Starter
JasonStebbins
Sounds like the CPS (very common) or the ECM. As suggested, wiggle the three connectors while running. Any change in idle is bad.
Any starting problems after it dies?
Fuel filter in good shape?
Are your battery clamps/terminals/grounds clean and tight? Even if they are shiny, remove everything and thoroughly clean them. Check the wiring on the positive and negative a couple inches back. Look for frayed/burnt wires.
Poop
JasonStebbins is offline
post #67 of 283 Old 12-05-2012, 10:52 PM
phitmein
phitmein's Avatar
" If you own a ZJ, you know all too well about oil leaks. The three notorious leaks are caused by bad valve cover gaskets, the oil filter adapter and the rear main seal."
You might want to add the oil pressure sending unit to that list.
It can make oil pour out the motor.
Phit
Edit: Great job on the write up Jason.
phitmein is offline
post #68 of 283 Old 12-05-2012, 11:49 PM
nwzj_jeeper
Phit
That's what happen to me the pressure unit was spraying oil everywhere.
post #69 of 283 Old 12-06-2012, 06:33 AM
LeeZJ
On the headlights flickering issue.
When I change my lights to full beam and off again I lose all light from my headlights for a couple seconds each time. It scares me everytime but when your standard headlights aren't great I have to stick full beam on where possible.
Would this fix solve that issue or something else entirely?
Great post. Thanks Lee
LeeZJ is offline
post #70 of 283 Old 12-06-2012, 09:56 AM
razortec_hunter
Anyone have a write up on replacing heater core??
razortec_hunter is offline
post #71 of 283 Old 12-06-2012, 04:26 PM
oldmancrash
Subscribed
oldmancrash is offline
post #72 of 283 Old 12-06-2012, 05:08 PM
nwzj_jeeper
There are a few in the other threads. Just hot to demos the while dash and ect . I need to replace mine it get annoying all the foggy/steam that comes out if vents.
post #73 of 283 Old 12-15-2012, 11:47 PM
nakedfrog
With regard to:
8. No Intermittent Wipers/Won't Go Back "Home"
This is a very annoying problem. Start by checking fuses in the kick panel and under the hood.
Second, replace the intermittent wiper control module velcroed under the driver side dash or under the removable grille under the windshield. It is a little black box and the wires run to the steering wheel or wiper motor. Also test and replace the intermittent wiper relay in PDC (Power Distribution Center).
It seems worthwhile to mention this thread, it really is a simple fix versus getting a replacement wiper module, for folks who aren't afraid to do a little soldering. I just did it tonight, and it was pretty simple.
nakedfrog is offline
post #74 of 283 Old 12-16-2012, 10:08 AM
ZeeJay1997
It's also worth mentioning that the >96 models do not have this module. It's right in there with the blinker fluid.
ZeeJay1997 is offline
post #75 of 283 Old 12-16-2012, 11:39 AM
NJ2MDJim
Seriously nice write-up. Thanks!
NJ2MDJim is offline
