Common ZJ Problems / Tutorial On How To Fix Them - Page 4 - JeepForum.com
 1Likes
post #46 of 283 Old 11-06-2012, 04:36 PM
tyler_t
Originally Posted by JasonStebbins
Sounds very much like a faulty TPS (Throttle Position Sensor)
Do you have more information on the problems that the TPS causes?
Built Not Bought #682
tyler_t is offline
post #47 of 283 Old 11-06-2012, 05:12 PM Thread Starter
JasonStebbins
Slight intermittent misfire.
Loss of power/sputtering/stalling.
Erratic RPMS.
Shifting problems.
Poop
JasonStebbins is offline
post #48 of 283 Old 11-06-2012, 05:31 PM
tyler_t
Erratic RPMS.
Shifting problems.
Yeah, that sounds about right. It seems to cut out while it's in third gear but if I press the gas and get it to about 45 while going uphill it seems to stop. Jason I wrote you in another thread about your headlights.
tyler_t is offline
post #49 of 283 Old 11-06-2012, 08:41 PM Thread Starter
JasonStebbins
Replace it with Mopar/NTK brand or your problems will persist.
Sorry I post a lot on here, didn't notice it. Yes I have the ZxE? Silverstars and they work great with my new headlamps. I can't justify spending $300.00 on the Kolak or Halo upgrade.
Make sure you adjust them, especially if you are lifted.
Poop
post #50 of 283 Old 11-07-2012, 04:35 AM
tyler_t
You are the first person that I've found that uses them, and I was wondering how they were. I don't really want to purchase Kolaks upgrade or anything like that, I'm cheap. But I will have more when I add the KC lights on the roof. What kind of lense housing did you buy because I can't seem to find any?
tyler_t is offline
post #51 of 283 Old 11-07-2012, 09:00 AM
jeepgirl1321
absolutely loved this. laughed at half of them, glad im not the only one with a bipolar jeep!!!! I love the thread. keep it up!!! :
jeepgirl1321 is offline
post #52 of 283 Old 11-07-2012, 04:22 PM
Montaska
Montaska's Avatar
2016 KL Cherokee
My mechanic said I have a parasitic drain, ah ha! Will try your suggestion out. Thanks!
2016 Cherokee KL Latitude ADI
- 1.5" MFC Lift
- 245/70R17 Cooper Discoverer A/T3
1997 ZJ: Sold | 2002 WJ: Sold | 2007 JK: Sold | 2016 KL: Current
Montaska is offline
post #53 of 283 Old 11-07-2012, 04:32 PM Thread Starter
JasonStebbins
Just a set of new lenses on eBay. I'm very happy with my night time output and radius.
I seemed to have acquired one in the last two weeks. Having trouble starting in the morning since it's been cold out.
Poop
post #54 of 283 Old 11-07-2012, 09:59 PM
steeptrail
Thanks Jason!
I've been driving around for years wishing the steering in my 93 ZJ wasn't loose. I even bought and installed a reman gear box after unsuccessfully trying to resolve the problem by doing the over-center adjustment. The new gearbox was EVEN WORSE! After reading your 12 things post, I read the attached TSB and did the bearing preload adj which fixed my problem!! Thanks for taking the time to post it!
steeptrail is offline
post #55 of 283 Old 11-10-2012, 04:31 PM
evals
Like I said I'm new and sill finding new threads so I'm reposting this in here cuz it fits. I really could use any help. Btw the filter is new also. Throttle down shift cable has very little to no play. About .25 mm of free play. Don't know about the tps. A transmission shop said it was something deeper and needed rebuilt. I really can't afford that right now.
Originally Posted by evals
I'm new to this form and am having a shifting problem. I have a 96 grand Cherokee Laredo with the 42 re transmission. It has 120,000 miles on it. When I'm driving and the transmission is up to full temperature it starts to miss shift. It will jump from 2nd, 3rd and OD to what feels like neutral for just a split second and then back into gear. Fluids are new and had the governor solenoid and transducer replaced. There is no feeling of slip in it. I'm not very good with automatics so please spell it out for me. I've always been a manual transmission person. Manuals are simple to work on however this automatic has me kinda intimidated. Any help would be great. Thanks
evals is offline
post #56 of 283 Old 11-19-2012, 08:58 PM
TallyZJ
Originally Posted by JasonStebbins View Post
Going to add some more today. Anybody have a request?
Add to "Miss at Idle/Erratic Idle"
- Check and/or replace injector o-rings
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #57 of 283 Old 11-19-2012, 09:09 PM Thread Starter
JasonStebbins
Glad it helped you. I did this awhile back and was very happy at a 1/4" turn.
Just added it.
Been having problems with the links I used, some of them aren't working anymore. I'll have to go back and re-paste them I suppose.
Poop
post #58 of 283 Old 12-03-2012, 03:12 PM
jeepgirl1321
Any ideas on why my 4.0 would literally shut off when im driving? everything else stays on. Fixed any loose connections...pleasee help!
post #59 of 283 Old 12-04-2012, 08:17 PM
Wheeler97
Awesome thread! I have a feeling I will be reading this one a lot
Wheeler97 is offline
post #60 of 283 Old 12-04-2012, 09:31 PM Thread Starter
JasonStebbins
Could be a number of things. What does it do when it dies?
Fuel pump/CPS/Alternator/Battery/TPS/Upstream oxygen sensor/ECM
Post some symptoms of what happens before/when it dies.
Poop
