Common ZJ Problems / Tutorial On How To Fix Them - Page 3 - JeepForum.com
 1Likes
post #31 of 283 Old 11-02-2012, 11:09 PM
Concolour
1994 ZJ
Originally Posted by LordBhael View Post
"Third, flush the coolant system. There is a plug at the bottom of the radiator that makes this an easy process. Please don't do this while engine is warm."
Back when I was a teenager, I watched my step-brother do basically that exact thing. We were driving and he notice the engine seemed to be getting a little too warm. We pulled over, he popped the hood, reached for the radiator cap and burned his hand. SO HE GETS A TOWEL AND OPENS THE CAP!!! Luckily he jumped back and somehow didn't burn himself bad. I'm a ***hole, so of coarse, I laughed my butt off.
back in highschool we ran into a situation where we had to open the radcap while things were running and what we ended up doing was grabbing some coveralls and engulfing the entire cap with them so any spray was right into the fabric and not on us when we opened it
Concolour is offline
post #32 of 283 Old 11-03-2012, 11:09 AM
Cymro
Brilliant post Jason, very informative, and a good starting point for the beginners, just hope they use it.
Cymro is offline
post #33 of 283 Old 11-03-2012, 05:23 PM Thread Starter
JasonStebbins
I actually did this somewhat when I flushed my coolant. That's why I added the last part. I let the engine cool for about 15 minutes while playing fetch with my dog. I took off that plug on the bottom of the radiator thinking that was a long enough wait. Wrong. As soon as I turned it 90 degrees the plug flew off and coolant sprayed out like a jet stream. Luckily I was laying to the side and using channel locks to take it off.
Thank you sir. It was worth the few hours of writing. These ZJ's can be a pain sometimes, and the fix is usually pretty simple. I'd rather have a new guy learn to wrench on his own vehicle rather then go to the shop and pay an arm and a leg for a hack job with cheap parts.
Poop
JasonStebbins is offline
post #34 of 283 Old 11-04-2012, 02:08 PM
codyhazzard
what is the common problem or short with the #7 fuse for the instrument cluster? like where is the common short or what causes it to be a parasitic draw?
codyhazzard is offline
post #35 of 283 Old 11-04-2012, 02:13 PM Thread Starter
JasonStebbins
Usually caused by a faulty BCM (Body Control Module). It is located under the driver's side dash. Commonly needs re-soldered or replaced altogether.
Poop
post #36 of 283 Old 11-04-2012, 02:44 PM
codyhazzard
I already re-soldered them, when I did a parasitic load test i only had .220mA but when I pulled the #7 fuse it dropped to .018mA so is there anything else other than the BCM that are normally shorted in that circut?
post #37 of 283 Old 11-04-2012, 03:36 PM Thread Starter
JasonStebbins
Brake light switch.
All four door modules.
Trailer tow circuit breaker.
Rear wiper motor.
Lift glass limit switch.
Speaker amplifier under the rear seat.
Automatic headlight sensor.
There's some things that are in that circuit.
Poop
post #38 of 283 Old 11-05-2012, 11:01 AM
codyhazzard
is there somewhere i can find out everything that is on that circut? or is that all that is on that circut?
post #39 of 283 Old 11-05-2012, 03:29 PM
tyler_t
Great thread, tons of valuable information!
Built Not Bought #682
tyler_t is offline
post #40 of 283 Old 11-05-2012, 04:45 PM Thread Starter
JasonStebbins
That is everything on the circuit.
Hope it helps you in the future.
Poop
post #41 of 283 Old 11-05-2012, 06:16 PM
NJ2MDJim
Very nice thread. Thanks!!
NJ2MDJim is offline
post #42 of 283 Old 11-05-2012, 07:12 PM
tyler_t
Oh it definitely will. It answered so many of my questions that I had. The biggest thing right now is the cutting out/loss of power during acceleration.
tyler_t is offline
post #43 of 283 Old 11-05-2012, 07:46 PM
booked101
bookmarked for later reference. thanks
good gas mileage is highly overrated.
(J)ust(E)mpty(E)very(P)ocket
booked101 is offline
post #44 of 283 Old 11-05-2012, 08:32 PM
codyhazzard
alright just wanted to make sure, im not even positive thats where the draw is coming from, .220mA isnt an excessive draw, im probably gonna replace all the battery wires then if that doesnt help test all those circuts
post #45 of 283 Old 11-05-2012, 08:49 PM Thread Starter
JasonStebbins
Sounds very much like a faulty TPS (Throttle Position Sensor)
Let us know how the battery wires go. We're here to help.
Poop
