Common ZJ Problems / Tutorial On How To Fix Them - Page 11 - JeepForum.com
 1Likes
post #151 of 283 Old 12-24-2013, 10:09 AM Thread Starter
JasonStebbins
Originally Posted by AAA View Post
Nice thread. You should also include the elusive rear clicking sound under acceleration or deceleration. I kept hearing a click coming from the rear of the vehicle when I would accelerate of hit the brakes either from a stand still or driving at low speeds, but I could never pinpoint where it was coming from. I had a friend drive the vehicle so I could listen on both sides, and I could never quite figure out what was clicking. Finally, I noticed that the Rear Upper Control Arm mounts had started to break away from the frame, and that was the source of my clicking. If your ZJ is lifted with short arms, check your rear UCA mounts for any signs of breakage, splitting or tearing. It's a fairly common problem. The fix is either to remove the mounts, repair the split or hole in the frame, then either replace the UCA mounts with aftermarket ones, or re-attach the stock brackets. This will take a good welder to fix this, as the ZJ frame is very thin and easy to burn through.
Thanks.
Not really something that an average garage mechanic can do, but it is pretty common. I'll throw up pictures of my UCA fix in a couple hours.
Poop
JasonStebbins is offline
post #152 of 283 Old 12-29-2013, 02:11 PM
babygirl1
I have an 07 commander and I've been getting transmission over temp message. I took my vehicle to the dealer and they told me I have a leak and recommended replacing the adaptor plug, which I had done. Now the vehicle isn't shifting out of first when I test drove it. Any suggestions?
babygirl1 is offline
post #153 of 283 Old 12-29-2013, 02:24 PM
SpectralZJ98
You likely cooked the solenoid and sensor. Maybe the valve bodies.
This would be a better place to find the answers you seek: http://www.jeepcommander.com/forums/
SpectralZJ98 is offline
post #154 of 283 Old 12-30-2013, 01:58 AM Thread Starter
JasonStebbins
Or just go here instead.
http://www.jeepforum.com/forum/f67/
An overheated transmission is very bad. A fluid change is the first thing I would do, along with changing the sensors mentioned above.
Poop
post #155 of 283 Old 12-30-2013, 09:08 PM
96gclscotty
Awesome. Much appreciated Jason.
96gclscotty is offline
post #156 of 283 Old 01-08-2014, 11:27 AM
Flo-grownJeep
Here's one to add to oil leaks. I Had replace and checked everything under oil leaks and my Jeep was still leaking BAD! It was the the hex adapter that the oil pressure sending unit screws into. It doesn't have a gasket. It's just screwed into the block with some sealant. Here's what I did.ose the whole area down with degreaser, then remove the pressure sending unit, then the adapter. Clean the threads on the adapter off well, if you can do it without dropping gunk and grit into the engine, clean those threads off too. Coat the adapter liberally with PTFE thread sealer compound (or whatever you prefer) and reinstall it. Make sure you point the pressure sending unit port in the right direction before the sealant cures.
Hope this helps.
Flo-grownJeep is offline
post #157 of 283 Old 01-11-2014, 10:26 AM Thread Starter
JasonStebbins
Hope this helps.
That's a new one I haven't heard yet, I'll throw it on there now. Thanks!
Poop
post #158 of 283 Old 01-19-2014, 12:25 PM
tcbays
Battery wont charge! I have a new battery and a new alternator, is there something else that is common to go out with the zj that will cause this?
tcbays is offline
post #159 of 283 Old 01-19-2014, 01:18 PM
LouC
2007 WK
What is your voltmeter on the instrument panel reading?
If you see a zero reading there and its not charging, are you sure all the terminals/grounds are clean?
In the ZJ voltage regulation is done in the PCM, so if that part of the PCM is bad, you can have that problem. Probably time for a new one.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is online now
post #160 of 283 Old 01-19-2014, 02:16 PM
joe19934
Originally Posted by JasonStebbins View Post
Going to add some more today. Anybody have a request?
Have you added :
Rear Defogger repair
Radio Diagram/Repair
VIC Repair
Check Engine Light Codes description
After market Bumper Build
Spare Tire Carrier
Transfer Case Swap
If You can't Go Around It then Go Over It !!!!!!!!!
joe19934 is offline
post #161 of 283 Old 01-22-2014, 01:59 PM
2tall2slow
hey Jason, in your amazing write up, I felt like you were describing my ride. Its like you have been in my jeep before or something.. in reference to t what you said about flushing the heater core, you ask if windows are fogging up for no reason, cab smelling sweet.. well mine started doing these things only AFTER I flushed my heater core. suggestions?
2tall2slow is offline
post #162 of 283 Old 01-22-2014, 07:05 PM Thread Starter
JasonStebbins
Originally Posted by joe19934 View Post
Have you added :
VIC Repair
Spare Tire Carrier
Transfer Case Swap
Never seen the radio diagram repair. I'll throw up the VIC soldering write up now that you mentioned it. Check engine light code descriptions can be found pretty much anywhere on Google. Bumper build/tire carrier aren't really repairs. Transfer case swap is in the stickies.
Time for a new heater core. Just did mine two months ago. Not a hard job, just time consuming.
Poop
post #163 of 283 Old 01-22-2014, 07:45 PM
RMCIII
This thread is awesome!!! BTW Jason, seems like a lot of people are reading it...
RMCIII is offline
post #164 of 283 Old 01-22-2014, 09:36 PM
nnovickzj
i read it super helpful having it all in one place good job
97 zj 5.2 40,000mi
locked front and rear, 242, 3.5 iro lift, 32x11.5 kenda klever, 28 laredos for the road
4x 130 watt 6" spots on the roof rack, h3 leds in stock fogs, 2 40w leds on the grill
nnovickzj is offline
post #165 of 283 Old 01-22-2014, 10:55 PM Thread Starter
JasonStebbins
I'm hoping it helps them as much as the forum and people have helped me over the years.
Tried to make it so less searching was required, and putting all the links saves time as well.
Poop
