Common ZJ Problems / Tutorial On How To Fix Them - Page 10 - JeepForum.com
 1Likes
post #136 of 283 Old 12-04-2013, 09:37 PM Thread Starter
JasonStebbins
Originally Posted by OCDComputing View Post
I may have missed it...but best practices for flushing a heater core.
Hmm. I linked a write up to replace it, but not flushing. I'll edit it now. You basically just need a garden hose and whatever type of cleaner you choose.
Edit - Added a flushing link.
Poop
JasonStebbins is offline
post #137 of 283 Old 12-05-2013, 10:36 AM
OCDComputing
Thanks for that! Great link.
OCDComputing is offline
post #138 of 283 Old 12-07-2013, 09:53 AM
housedl
wow.. we can delete the forum and just read this.
housedl is offline
post #139 of 283 Old 12-07-2013, 10:00 AM
SpectralZJ98
Just thought of something. Rear liftglass defogger grid repair. Have to take pictures, now
SpectralZJ98 is offline
post #140 of 283 Old 12-07-2013, 10:22 AM
Edwardmiller221
I've got a tough one. When I accelerate with the pedal more than half way down and rpms pass 3300 I start to backfire through the intake. No vacuum leak. I've replaced the crank sensor, tps and map sensor. The overall problem got slightly better with tps but still having backfiring. Only codes are misfire codes for different cylinders. Have disconnected battery for 8 hours. No difference. What should I try next? The tps and crank sensor are mopar parts. Map and iac are aftermarket. Forgot to add also misses at idle sometimes.
Edwardmiller221 is offline
post #141 of 283 Old 12-07-2013, 10:58 AM
SpectralZJ98
Clean your fuel rail, replace your fuel injector basket filters, and check your fuel line
post #142 of 283 Old 12-07-2013, 11:30 AM
Edwardmiller221
I forgot to include 97 5.2. Basket filters, I'll have to look that one up. Thanks. Also must state that she will do 80 on the highway with no problems.
post #143 of 283 Old 12-07-2013, 11:54 AM
SpectralZJ98
4.0, 4.2, 5.2, 5.9, same difference. You did your electrical components. Only thing left is the fuel system. You'd be surprise how overlooked the rails and basket filters are. Ebay has kits for fairly cheap, and its cake to clean them and the rails.
post #144 of 283 Old 12-07-2013, 12:02 PM Thread Starter
JasonStebbins
Check all these things to track down the misfire.
Worn spark plugs
Cracked distributor caps
Out of Phase distributor/rotor
Shorted rotor
Leaking plug wires
Low fuel pressure
Low compression
Sticking valves
Broken valve springs
Worn cam lobes
Incorrect valve or ignition timing
Leaking EGR
Vacuum leaks
Leaking Injectors
Clogged Injectors
Contaminated fuel
Low fuel tank level
Excessive EVAP purge
Low ignition system primary voltage
Cracked coils
Plugged exhaust
Excessive PCV flow
Wiring Harness
Faulty PCM
Poop
post #145 of 283 Old 12-07-2013, 12:15 PM
SpectralZJ98
^^^^^^ Yeah, what he said.
post #146 of 283 Old 12-07-2013, 12:37 PM
Edwardmiller221
• Worn spark plugs
• Cracked distributor caps
• Out of Phase distributor/rotor
• Shorted rotor
• Leaking plug wires
• Low fuel pressure
• Low compression
• Sticking valves
• Broken valve springs
• Worn cam lobes
• Incorrect valve or ignition timing
• Leaking EGR
• Vacuum leaks
• Leaking Injectors
• Clogged Injectors
• Contaminated fuel
• Low fuel tank level
• Excessive EVAP purge
• Low ignition system primary voltage
• Cracked coils
• Plugged exhaust
• Excessive PCV flow
• Wiring Harness
• Faulty PCM
Thanks for the list. Most is done. New coil cap rotor wires champion plugs. My confusion lies with the fact it will red line and not misfire until pedal is pushed beyond half way down. So if I don't pass half throttle will not misfire and will red line with no problem. Once dip farther into the pedal from past halfway to floor misfires passed 3300 rpm or so and of course will not red line and then throws the misfire code. So since it will red line prior to more than half throttle and drive at any highway speed with no problem leads me toward some sensor or possibly the pcm. But with no codes I'm pulling straws. Since it only effected by throttle position leads me to believe that all mechanicals and fuel system is good or I would see and issue passed that rpm across the board, ie any and all throttle position, correct?
post #147 of 283 Old 12-07-2013, 12:54 PM Thread Starter
JasonStebbins
So after half throttle, it starts to misfire? Is your catalytic converter original? Upstream oxygen sensor? Have you checked fuel pressure? Sounds to me like an exhaust restriction or fuel delivery problem.
Poop
post #148 of 283 Old 12-07-2013, 01:07 PM
Edwardmiller221
Yes after somewhere past half throttle. Will red line and drive normally unless I get heavy into the pedal. Cat and o2 sensors are original. But like I say will red line and run like a Swiss watch until push to far into the pedal.
post #149 of 283 Old 12-07-2013, 01:33 PM Thread Starter
JasonStebbins
When you're really on the pedal or downshifting, it's moving a lot more and air fuel. That's why I'm guessing CC or o2. You can try unplugging the oxygen sensor and go for a drive to see if the symptoms go away. Can't really test the CC without a heat gun, but if it's original it's probably not in great condition.
Poop
post #150 of 283 Old 12-24-2013, 05:30 AM
AAA
Nice thread. You should also include the elusive rear clicking sound under acceleration or deceleration. I kept hearing a click coming from the rear of the vehicle when I would accelerate of hit the brakes either from a stand still or driving at low speeds, but I could never pinpoint where it was coming from. I had a friend drive the vehicle so I could listen on both sides, and I could never quite figure out what was clicking. Finally, I noticed that the Rear Upper Control Arm mounts had started to break away from the frame, and that was the source of my clicking. If your ZJ is lifted with short arms, check your rear UCA mounts for any signs of breakage, splitting or tearing. It's a fairly common problem. The fix is either to remove the mounts, repair the split or hole in the frame, then either replace the UCA mounts with aftermarket ones, or re-attach the stock brackets. This will take a good welder to fix this, as the ZJ frame is very thin and easy to burn through.
AAA is offline
