-   -   Common ZJ Problems / Tutorial On How To Fix Them (http://www.jeepforum.com/forum/f13/common-zj-problems-tutorial-how-fix-them-1432264/)
JasonStebbins 10-27-2012 09:32 PM
Poop
JasonStebbins 10-28-2012 09:24 AM
Poop
ZeeJay1997 10-28-2012 10:05 AM
Good job, now people just need to read it before they post!
JasonStebbins 10-28-2012 10:16 AM
Poop
mflour 10-28-2012 12:01 PM
Nice write up, thanks
JasonStebbins 10-28-2012 02:06 PM
Just added two more. They came to mind as soon as I went for a drive in my ZJ. :laugh:
shortseller 10-28-2012 08:09 PM
Random how to requests I could think of:
Fuel filter change
Heated seat fixes/replacement
Interior/headliner disassembly
Power steering flush
Brake flush/stainless upgrade
iser 10-28-2012 08:38 PM
you should add heated seat repair. since it started getting cold, i've noticed a lot of people posting about it.
awesome awesome thread man. i'm really busy lately, but once things die down, i'll help you out. maybe some of us can put something together and finally update that faq properly.
SewerRat114 10-28-2012 09:31 PM
Awesome write up. I have lurked on here since i started looking for my ZJ and since i have gotten it i have researched and worked up a to-do list but this and the 12 step program and now my go tos.
Thank you
rcorn79135 10-29-2012 12:08 PM
I have one that you could consider adding to #18 belt chirp. On my '96 (4.0), I had a chirping belt when cold for a few days so I ordered a new belt and two new idler pulleys from Rock Auto. On replacement day after changing the belt and both pulleys, it still had a chirp when revving the engine. While watching the belt while revving the engine, that's when I noticed the pulley portion of the harmonic balancer moving in and out. Inspection of it showed that it was beginning to come apart - the isolating rubber was bulging out and I could pick it off. Fortunately the local parts store had a new Dorman balancer for $45 and with a short harmonic balance puller, it could be pulled without removing the radiator. I figure the balancer was so cheap compared to some others because it has no reluctor wheel on it since our crankshaft position sensor is located in the bellhousing.
bananaslug 10-29-2012 12:26 PM
Some how-to's I have book marked:
transmission cooler
http://mallcrawlin.com/forum/showthr...oler-upgrade!&
taurus fan
http://mallcrawlin.com/forum/showthr...ord-Taurus-fan
trunk latch
http://www.jeepforum.com/forum/f13/w.../index927.html
5.9 alternator in a 4.0
http://www.jeepforum.com/forum/f11/5...pgrade-642951/
diagnostic codes
http://www.jeepforum.com/forum/f13/9...6/#post5980112
WJ manifold swap
http://www.mallcrawlin.com/forum/sho...L-DYNO-NUMBERS!
crank sensor replacement
http://www.jeepforum.com/forum/f13/1...ement-1168716/
wheel bearing replacement
http://www.nagca.com/grandtech/dana30wheelbearing.htm
242 t-case slitp and re-rtv
http://mechdb.com/index.php/Jeep_NV2...case_breakdown
valve cover gasket
http://www.jeepforum.com/forum/f11/v...-pics-1121533/
ball joints
http://www.jeepforum.com/forum/f13/z...ite-up-984507/
tps replacement
http://www.jeepforum.com/forum/f9/th...te-up-1371616/
wiper motor repair
http://www.jeepforum.com/forum/f13/s...-motor-398760/
coolant temp sensor
http://www.jeepforum.com/forum/f13/t...fixed-1360518/
adding fog lights
http://www.jeepforum.com/forum/f13/z...ts-how-251475/
4.0 timing chain
adding hood vents
http://www.nagca.com/grandtech/hoodvents.htm
JasonStebbins 10-29-2012 02:13 PM
Fuel filter change
Just added the heated seat repair and headliner removal. The fuel filter is pretty self explanatory. If it's outside the tank it's just two clips. If it's inside the tank you just have to unscrew the two gas tank straps and remove the two filler hoses and drop the tank.
Power steering and brake fluid flushes can only be done with with suction devices/bleeding the brakes so it's not really something that needs explained.
Just added your information to belt chirp. :highfive:
Those aren't really common problems that people deal with on a daily basis, but the links are good to have accessible.
shortseller 10-29-2012 02:21 PM
hahaha if I had this thread 6 months ago I would have saved 6 months of searching and reading. Thanks guys! keep them coming.
JasonStebbins 10-29-2012 06:46 PM
That's usually how it goes. :laugh:
I've experienced just about all of these problems that's why I know so much about them. Lol.
ZeeJay1997 10-29-2012 07:21 PM
Okay Jason, I repaid you for linking my post, check out the end :thumbsup:
The time now is 06:25 AM.
