Command Center says "Rear Light Failure" - JeepForum.com
post #1 of 5 Old 09-26-2009, 08:51 AM Thread Starter
RichB
Hello - I have a message on the command information center ( 95 GCL) that indicates that I have a rear lamp failure.
All the taillights work properly......how do I get this message to go away?
Any help is appreciated?
Thanks - Rich
RichB is offline
post #2 of 5 Old 09-26-2009, 09:25 AM
taythegibs
how long has it been up?
if it just appeared then start with the basics, you have a 3rd brake light that has 2-3 bulbs right? check it and make sure they are all working. i did a writeup but im not sure it will help you>http://www.jeepforum.com/forum/f197/...re-fix-859010/ walmart also sells the bulbs.
if replacing the bulbs doesnt work then you might have a bad connection so make sure they are clean.
hope that helps.
-Gibs
Not Jeepless anymore!
Originally Posted by Swagger_Wagon View Post
When people JF drunk is when most of the gold comes out.
taythegibs is offline
post #3 of 5 Old 09-26-2009, 10:54 AM
my-jeep-earl
1971 CJ5
I've got the same problem with my '97 all my tail lights worked, couldn't figure it out. Then one day I noticed it was my third brake light, I'll probably fix it this weekend.
my-jeep-earl is offline
post #4 of 5 Old 10-11-2009, 09:01 PM Thread Starter
RichB
Thanks for the advice - I will change out the bulbs to see if that helps
RichB is offline
post #5 of 5 Old 10-11-2009, 10:06 PM
MN_NATV
Or you can do what I did, yank the VIC, gut it and mount a trans temp gauge in the shell. Plus you'll have extra room for switches for lights, air compressor, lockers, etc.
MN_NATV is offline
"Rear Lamp Failure" When Headlights Are On - 97 Grand Cherokee muellmk ZJ Grand Cherokee Forum 20 04-06-2015 11:11 AM
display says "rear light failure"..... firepiper ZJ Grand Cherokee Forum 11 01-23-2010 10:26 PM
ZJ "Rear Lamp Failure" message DonPud4x4 ZJ Grand Cherokee Forum 8 01-29-2007 02:12 PM
Computer reads "rear lamp failure" but theyre fine. whats going on user jeep ZJ Grand Cherokee Forum 5 08-03-2006 09:57 PM
"Rear Lamp Failure" but its fine jeepcherokeev6 ZJ Grand Cherokee Forum 4 06-20-2002 04:39 PM
