Cold oh so Cold no Heat - mostly not blend door. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Cold oh so Cold no Heat - mostly not blend door.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineHMF Fabrication 50" Light Bar Mounts for CJ/YJ Made IRuffstuff XJ Unirail Channel Reinforcement....
Unread 03-14-2008, 05:53 AM   #1
Jawa78
2008 MK Compass
Now I read hunderds of threads on Blend Door issue. But other then the fact that I get NO Heat at all just outside air temp coming through the vent. I know it out side air temp as I have a infrared gun. Anyway, I started her up and idle for a couple of minutes, and hit the about 160 engine temp then drove it aroudn the block once and it got up to 210 or just a hair past 210.
Well I pull back into the drive way and let her idle and she staying at 210 and I poped the hoodand pointed the infra gun at the heater core pipes and they are reading 90F my morning starbux was hoter then the pipes when I touched them.
Is the heater core plug or could something else be wrong.
Oh forgot to mention there are no error codes hence another reason why I dont think it is blend door issue.
Never mind it blend door now code 52,54,56
Jawa78 is offline   Reply With Quote
