#1 | |
coil springs on a zj
can you use the front coil springs on a zj and put them on the rear and buy taller front springs for lift?
#2 |
"Si Vis Pacem, Para Bellum" '98 ZJ Limited V8 "Daisy" |
#3 |
Yes, you can, if you mozy on over to ironrockoffroad.com they have a 3.5" kit that does just that
IRON ROCK OFF ROAD: ZJ 3.5" Lift Kit I run it and the one i linked you is all you need but i would go ahead and add in a rear adjustable trackbar, its is very nice to have so you can center your rear axle under you. There is some debate as to whether the I6 springs will provide he full 3.5" as the v8 springs are recommended but you can always try it out and see before you you get v8 springs from the junkyard or something. Other than that i would recommend the JKS quick discos but its not necessary and the bilsteins are a dream but are are pretty damn pricy compared to the others available.
-James Got to love an ORVIS guy... IRO 5.5", Front LA & Double Sheer TB, Rear Adjustable SA and TB, JKS Quick Discos, DT8Ks 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs JCR Stage 2 Sliders, IRO Trans Skid |
#4 |
#5 |
Most common way of cheap lifting, aside from BBs.
Read the FAQ, F>R swap section.
DD: 98 ZJ Laredo 5.2, all stock Wheeler/Beater: 93 ZJ Laredo 4.0, AW4, 231 conversion from 249 3" coil lift, JKS Adjustable Track Bar, JKS Quicker Discos, KOR lwr rad supt, Brush guard Colorado Jeep Club Member 242 (4.0L) |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
