Coil spring isolator question! - JeepForum.com
post #1 of 10 Old 07-30-2013, 06:03 PM Thread Starter
ZJNewbi3
So I'm installing a 2" BB soon and I ordered two different isolators (NOT spacer) the fronts are MOOG from RockAuto and I got the rears from IRO. The thing is, the MOOG ones are 4" in diameter and the IRO ones are around 3.75" diameter. If you place the two on a spacer, the MOOG one fully covers the spacer when the IRO one doesn't. Eyeballing it, it doesn't look like the IRO ones would fit.
I just want to know if this is a big issue or not? Should I just order 2 more MOOG isolators and throw them on the rear? I only have 3 days before the lift starts.
Side note, the spacers are from RE, all 4 of them are completely round. The front isolators are round, the rears are D shaped.
ZJNewbi3 is offline
post #2 of 10 Old 07-30-2013, 06:50 PM
BrandonsZJ
I have used the IRO coil spring isolates on my 2" bb and they are factory replacements. I bought the front and back from them and they do work. You are correct the fronts are round and the rears are d-shaped. I put the isolators on first and then the 2" spacers.
BrandonsZJ is offline
post #3 of 10 Old 07-30-2013, 07:11 PM Thread Starter
ZJNewbi3
Ok that gives me more confidence but why would the 2" spacer be a bigger diameter than the isolator?
ZJNewbi3 is offline
post #4 of 10 Old 07-30-2013, 07:16 PM
BrandonsZJ
I'm really not sure if it was bigger or not. I think it might have been actually. I don't know why it is bigger, maybe to give it more strength.
post #5 of 10 Old 07-30-2013, 07:36 PM
BrandonsZJ
I just checked and my front isolators and 2" bb are pretty dam close to being the same size.
post #6 of 10 Old 07-30-2013, 07:42 PM Thread Starter
ZJNewbi3
Mine isolators are 0.25" smaller than the spacer in the rear. Hope these work. Thanks for the replies! Now I gotta figure out how I'm going to pound my 2" exhaust extension in the isolator haha.
ZJNewbi3 is offline
post #7 of 10 Old 07-30-2013, 07:53 PM
BrandonsZJ
It should work though. I didn't even install extensions.
post #8 of 10 Old 07-30-2013, 09:30 PM Thread Starter
ZJNewbi3
Yea I'd rather do extensions to be safe than sorry
Just trying to keep her goin'!!
ZJNewbi3 is offline
post #9 of 10 Old 07-30-2013, 10:16 PM
xcaliber81
If my isolators are worn should I replace them?
xcaliber81 is online now
post #10 of 10 Old 07-30-2013, 10:49 PM Thread Starter
ZJNewbi3
Honestly I would...Mine are so bad that the rubber is all torn up and the metal plate inside its exposed and rusted to heck. Just poking at it made chunks fall off I live in Wisconsin so it sees salt.
ZJNewbi3 is offline
budget boost , coil spring , lift + spacers
